20 Most Recent
LG RU52SZ30 52" Television Questions & Answers
MY LG MODEL RU52SZ30 ( 2003), HAS A YELLOW LIGHT
Yes, the lamp is nearing the end of life when the lamp light is a steady orange (yellow). Order a new one and replace it. (When other parts of the lamp system fail, you will see a blinking red light.)
I hope this helps.
My 52" LG LCD Projection
What is the service model? Please include the .AUS... info also. There are many sources for parts.
Ballast 6913v00002c is a different size than the original
The old and the new parts have same model's of tv and same parts #---.All way fit,if the parts of the tv is one of the main componnents that make the tv work.Talk to ur ventor u buy it from yet?Explain the problems,work somethings out.
Solution for tv
Bad Lamp.Or defective Lamp Fan. Encompass Parts 1-800-638-3328
Blue didcoloration lg ru52sz30
This is a manufacturer defect in the light engine. There is a class action lawsuit that was settled to extend the warranty and cover this repair for FREE. If you call LG with your model and serial number, they should direct you to the extended warranty department and set up the free repair. Details on the settlement are available at
http://rearprojectiontvsettlement.com/index.htm.
MY TV has a blue cloud on the left side
Blue lcd is burnt up.. Normally happens due to excess heat from poor ventilation or not changing the lamp at the required time.. Allways happens on the blue as blue light is the hottest wave length, and as the lamp burns, it shifts to that side. Nothing you can do but replace the lcd itself. From the image shown, looks like the unit uses sony lcds.. Sonys are well known for there burns.. No quick fix on this one.
HOW TO REPLACE LAMP IN
hi for the lamp replacement ,you have to undo lamp cover from right hand side and then slide out thelamp case .to reset the lamp time,you have to press 'mute' on your remote and press 'ok' at the same time on front panel.
Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
