20 Most Recent
LG 32LC2D Television Questions & Answers
LG32LC2D - Sound slow to start
This is indicative of a bad main board that will need replaced. For this model make sure the repair person has the full product code (from the back of the unit) so that they can get the correct main board ordered (there are multiple versions depending on the product code). Hope this helps.
11/13/2016 4:22:55 AM •
LG 32LC2D...
Answered
on Nov 13, 2016
How do I get audio out of 32lc2d to go to the external surround sound system
Depends on your external sound system... If it supports HDMI, then just connect an HDMI lead between the TV and the external amp. If you don't have HDMI, look for two RCA/Phono connectors (small circular connectors) on the back of the TV (should be coloured red & white) and connect these to the external sound system. Finally, if you don't have either of these look for a 32 pin scart socket (rectangular with a bit sticking out) and get a scart to phone cable. Plug the scart plug into the TV and connect the Red & White output leads to your external system - hope that helps :-)
8/18/2014 9:45:39 PM •
LG 32LC2D...
Answered
on Aug 18, 2014
NDIZET NORMAL MENU NORMAL FUTET NE KERKIM DHE
If you wish to get more details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to
Mosaic
/ Time slide, can be selected by the
drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.Translation option is there, can be pulled out by the right side bar.
10/28/2013 12:49:46 PM •
LG 32LC2D...
Answered
on Oct 28, 2013
Tv code blink
If you wish to know more about the blinking codes to TVs, and others, check the site linked here. It blinking codes details to many brand TVs.
Pull up previous posts by its left sidebar, or type in the
brand name and model number to of your set, to its search box, and
press '
Enter' or view it in
Mosaic / Timeslide
option.
10/3/2013 4:09:58 AM •
LG 32LC2D...
Answered
on Oct 03, 2013
