20 Most Recent
LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher Questions & Answers
LG Dishwasher Model LD-14AW3
I have had this dishwasher about 4 years, it has work beautifully, then one day there just wasn't any power going to it. Have tried different power points and no change. Looked for a fuse, was unable to find one. The power cord coming into the machine is undamaged. Any suggestions.
In a kitchen remodel, I am installing the
If it were me I would use a small hole saw and run my braided stainless lines below the kick plate if code allows or at the back of the adjoining cabinet at a height which would not conflict with contents. You can buy an ABS dishwasher drain kit at Lowes or HD
Im receiving an OE error code on my LG Dishwasher
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Suspect door spring/assembly broken. How do I repair same?
If it's like my whirlpool, pull it out. Spring should be obvious. I doubt the hinge portion is broken. Spring may be. While it's out and springs tend to break, I would replace both. Several online appliance parts stores can help you with springs, my diagnostics and Hinge issue. They have been helpful to me.
Dishwasher blockage
there is a removeable filter at the bottom of the wash pan. It is usually a "screw-in" type of ring. See if this website can help..
www.applicancerepair.com -enter your make and model and search
Where are the filters on an lg dishwasher?
Your dishwasher may have a filter located near the bottom or under the lower spray arm. This filter should be inspected and cleaned regularly. Follow your dishwasher owner's manual for specific instructions about how to properly remove and clean this filter, if equipped. If there are any holes or other damage to the filter, you'll need to replace it immediately to protect the dishwasher's pump and motor seals from damage.
My LG dishwasher (LDF7810WW) makes a whining noise
MINE IS A LG 3850DD3006A AND YES THE GARBAGE DISPOSER GETS STRAWS AND JUNK IN IT. OR THE SCREEN ON THE TOP IS COVERED WITH MACARONI AND CHEESE. OR TWICE IN 4 YEARS THE MOTOR RING SPLIT AND THE MOTOR STARTED TO GRIND THAT RING TILL IT STOPPED ALLTOGETHER.
WHAT A PEACE OF JUNK!!
I ADMIT THE STRAWS ARE THE USERS FALT!
