20 Most Recent
LG WM1815CS Front Load Washer Questions & Answers
Washer not draining
Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.
Wm1815cs doesnt doesnt spin
No spin, or lite spin try these: Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Or try the hand test: If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test.
WARNING:
This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a bloody death. Proceed at your own risk! Have a nice day. - put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand - turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin - if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand - if it takes very little force to stop the tub from spinning, the clutch needs to be replaced. Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either) Next if belt driven check for a loose, worn or broken belt. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle. On some front load models u may need to check the STATOR assembly. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed. Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand. And in some models check with a meter for continuity and voltage. next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,basket driveor the tub drive block If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer. Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washer http://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiN By the way my advice is free cuz God is good!
Not the drain pump...
you may have inadvertently left a switch disconnected in the frame or the drum area..so when it reaches that part of the cycle, it just stops because the circuit is open..
How to replace the drain motor
try checking the filter or coin trap before you try to replace the pump. on an LG replacing involves removing the front of the machine, pretty big job if you don't know how.
Burning rubber smell inside of tub after wash is completre and tub bangs on sides
Hello, michaelI
am trying to help you out here. Maybe this will help some? I am know on
Fixya as the cleanup expert pro. Which means I spend my own personal
time to seek out customers that maybe have not had there problem yet
solved by the other fantastic great experts. I do this on my own for
free. Think of me as a Specialized Trouble Shooter.I have found
out that it appears that lots of customers appreciate my efforts and
help. So, I thought I would take some of my own personal time to
see if I can help you. Even though this Informational site may not have
your exact model or brand, But this site will help you a lot. Here is
the site link about everything you want to know about washing machines and possibly yours, from repair to trouble shooting it.http://home.howstuffworks.com/how-to-repair-a-washing-machine.htmPlease
if this helped you at all, if you can find the time and in your heart
to rate my help and some kind words written would be appreciated for my
free help, I would appreciate it. Like I said I
just try to help, If anything this is good information for future
problems. If you felt that my free help was a waist of time for you, I'm
sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.Here
is also my direct link to my own pages of other areas of my expertise
for other problems you might have in Automotive, Appliance, and
Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1beanThanks Mike
Why do i keep get a OE reading?
Hello, ironI
Water leak from the front of the machine
Clean off the bottom of the door glass. If hair or lint builds up there, it dose not seal completely and a little water will run down the front of the machine. If that does not solve your problem, you can try moving the spring clamp (which holds the front of the tub seal)so the spring part is moved to the hinge area (a 80 degree move) instead of at the bottom of the door.
My LG front load washer
'OE' for LG washing machines definitely decodes as 'drain error', sorry!
I know you say that you check the drain hose and filter but have you checked the drain motor/pump as well?
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
I have an LE code on my washer. I tried resetting
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
