20 Most Recent
LG WM2042 Front Load Washer Questions & Answers
Front leaking
It sounds like you are over-filling the drum with water. Check the fill switch. If the fill switch is bad, it will not stop filling with water.
I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
DE code, machine will not run. door working
DE indicates a door lock error.
Either
the door lock, wiring or main control board can cause this fault. The
door lock is relatively inexpensive so it would be worth trying a new
door lock first.
Check the wiring between the door lock and the
control board. If a new door lock doesn't fix it and the wiring is ok
you are only left with the control board.
Hope this helps.
Uneven load
For my washer it means the drain hose is bent/ clogges or the drain filter is clogges
Hot water not entering washer, not a hose or solenoid problem...
Before ordering a new control board, check the wiring harness to make sure there are no breaks in the wire from the water valve to the board. If everything checks out, replace the board. The board is not that hard to replace and all the wire connectors are not confusing.
Machine doesnt start. the wash and spin indicator lights blink alternating
first try unplugging and waiting a minute and then plug in and see if that resets it. if it does not try unplugging, wait a minute, hold power button in for 15 secs and then plug back in and see if that resets it. and finally, try the second one and continue to hold power button in while plugging back in. all are different ways of resetting some washer models. one might work for you and cannot hurt to try. good luck
LG Fuzzy Logic 8.2 kg top louder WF-8071TTP
This dE error or fault code to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
LG error code
its best to get an engineer to the problem as it could be anything at all or just an alignment problem eric
