20 Most Recent
LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher Questions & Answers
LG Tromm - soap drawer is stuck and will not open
This is caused by the "Fabric Softer" removable tray inside the drawer getting stuck in the top of the drawer cabinet.
Solution:
1. Unplug machine
2. Remove four sheet metal screws and plastic plates from top of back of machine that hold the "lid" on (perhaps yours is different and only has two screws, but that's your world :) )
3. With the palm of either hand hit the both sides of the lid of the machine at about a 45 degree angle towards the back of the machine until the lid slides back about 4 inches
4. Gently remove lid (will lift off easily if you've freed it correctly)
5. On left you'll see a white box which is the cabinet for the drawer. Carefull pull the black wire from it's retainers
6. Lift up the three clips on the right side of the cabinet that hold it together
7. In the back of the cabinet, grab ahold of the plastic piece that doesn't have a hose attached (unless yours does, in which case figure it out yourself :) ) and gently pull up until you can see the cabinet coming apart in the back.
8. When you have enough clearence push a screwdriver through the opening you've created while lifting on the back of the cabinet apart, and PRESTO! The drawer will pop out.
This will happen everytime from now on if you do not remove the the "fabric softner" tray from the drawer. It is a design flaw that will happen to all models eventually. If you must have that little tray, then find a solution that works and post a follow up here (I imagine it will involve a bench grinder :) )
HAPPY WASHING AND BUY AMERICAN!!!
Grease stains on clothes from LG washer (tromm 2688)
We run a small hotel and have been having this same problem with our LG Direct Drive WM2301HW... but the stains aren't grease at all... they're from sledge buildup in the washer. I found this out when I cleaned the lint trap behind the small door at the bottom left, on front of the machine. I ran my finger around the interior and found it lined with black, stinky muck. Due to the low position of the filter, this area never fully drains, so the muck collects and the bacteria grows. Of course, this means the pipes or hoses to the filter are probably also lined with this muck.... Poor design!!! Try running the washer empty (no clothes) with a couple cups of honest to goodness chlorine bleach. Then run it again to make sure all the stuff that came loose gets pumped out.
Not working start button only
first check the lid switch. its a magnetic switch which tells the machine that the door is closed for it to start its operations. if that switch is OK then maybe your
push in button needs replacing.
Still getting LE code after replacing Hall Effect Sensor
i would guess you are getting a "tE" error code. that is a bad thermistor. pretty common. and it starts out as an intermittent error. it really is an easy fix. great online videos. check out appliancepartspros.com for both video and parts or repairclinic.com for video and parts. or youtube.com
My lg dle0442w wont dry clothes blows cold air
Sometimes it is the heater element in the dryer. Other times the main circuit breaker has tripped one leg. Some 220V-230V breakers have two trip switches that are tied together. One half of the breaker runs the motor and the other half operates the heater. A defective breaker can also cause the problem.
How to select "SPIN ONLY" cycle?
I TOO HAVE BEEN WONDERING HOW TO SPIN ONLY, AND I HAVE THE ANSWER :),, TURN THE POWER BUTTON ON, PUSH THE SPIN SPEED BUTTON NEXT TO DESIRED LEVEL, THEN PRESS START, THERE YOU GO , IT WILL ONLY SPIN, NOT RINSE AND SPIN :), BY THE WAY , I GOT THIS INFO FROM THE ONLINE MANUAL :), SHOULD WORK....
LG Top Loader WF-T8108TP - NOT SPINNING
unplug the machine take the back off and look for a small pipe 5mm going upwards, take it off and blow gently into it you should hear a click and one when you let the air out if so then the place you took the pipe from is blocked clean out the pipe with a pipe cleaner or metal rod replace the 5mm pipe put the back on retry the machine eric
We have an LG Tromm Steamwasher WM2487HWM . 4.0 cu
Replace the boot with new. While you have top and front off to replace boot, hose the drum down with a hose on stream. Remove filter clean out as you hose it down. Btw, there is no cleaning off the boot if it has mildew/mold on it.. it's slightly porous and no eliminating it
I got my lg tromm
Just pushing the button labeled 'beeper' doesn't work? Turn pose on, press beeper
