20 Most Recent
KWorld DVD MAKER USB 2.0 (660448660114) Questions & Answers
Cannot get my PC running windows 7 to detect video
1. Your input device may not have the updated drivers for Windows 7
2. You can possible see if this device will run in the Windows XP
3. Use the "compatibility utility" that is featured in Windows 7
4. Here is the procedure from Microsoft page
http://windows.microsoft.com/en-US/windows-vista/Make-older-programs-run-in-this-version-of-Windows
5.
How do I get vhs video onto my computer?
You need a TV capture card... the package includes connectors for VHS & other DV cameras, you also need of course a VHS player..
While the VHS player is playing your VHS tape... the computer can now record it via the TV capture card.
That's what I do... goodluck and don't forget to rate...
HELP!!! CAN'T USE DVD MAKER 2 ON MY MAC. WHY IS THIS????
I was looking at the specs and it looks as if it is meant for the PC and not the MAC cause if it was meant to be used on the MAC then there would be specs for the MAC for the system requirements. I checked out Tiger Direct for the information:
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=612720&SRCCODE=GOOGLEBASE&cm_mmc_o=VRqCjC7BBTkwCjCECjCE
When i try to record the sound, it is only fuzzy!
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
hope this helps
I'm trying to import footage
your codec is not compatible with your system. please download from this link http://www.codecpackguide.com/klmcodec.htm to have codecs that your need. hope this helps!
Audio is Messed up on
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
