20 Most Recent JVC HR-XVC19S DVD Player/VCR Questions & Answers
It seems there could be a problem with the tv-dvd link. http://resources.jvc.com/Resources/00/01/00/LPT1086-001A.pdf the dvd manual can help alot
JVC HR-XVC19S... | Answered on Jan 01, 2017
Not all disks reflect the laser beam the same. If the lens is of lower quality then some light will be lost passing thru it. If on top of that the disk is less reflecting then the return laser light might not be enough to trigger the sensor - the disk is not recognized. If you were unlucky enough to buy a unit with a less than perfect lens then it's normal that even a very small amount of dust will have a big impact on the readability of the disks.
Sorry, manufacturing defect, there is nothing anyone can do. Use it as is or you will have to buy a new one.
JVC HR-XVC19S... | Answered on Nov 29, 2010
We did this:
Turn player of (standby) and clkick first on the pause and then on the open button.
The player goes out and then standby.
Problem was solved
JVC HR-XVC19S... | Answered on May 08, 2010
Hi dave
To answer your question;
In order to watch both the dvd and vcr on the same tv input , you need to use the dvd/vcr output of your jvc.
The component output is for the dvd only.
So if you want to keep the component output for high definition when playing a dvd you can connect another rca cable from the dvd/vcr output of your jvc to another input on your tv when playing vhs.
If you want the owners manual online you can find it HERE
You`ll find all the info on page 11
Hope this help Good luck
JVC HR-XVC19S... | Answered on Apr 27, 2010
I found the solution for my DVD player you need to hold source down for 5 seconds which will unlock the disc.
JVC HR-XVC19S... | Answered on Jan 12, 2010
Normally when the VCR is plugged in, the display should blink. If not, it could be broken. Since I am not sure about this model, do an experiment. Unplug the unit. Wait for a few minutes. Plug it back in and insert a video cassette. If it powers up and the display turns on, VCR should be OK. The unit may be reset to factory default and the remote might be set to different code. The remote can be reset to factory setting by removing the battery for a few minutes.
JVC HR-XVC19S... | Answered on Nov 15, 2009
Find the small hole on the front of the player. Get a small paper clip and straighten it out. Insert one end into the hole and the DVD should pop out.
JVC HR-XVC19S... | Answered on Aug 21, 2009
hey, this happened to me too. what you have to do is put it in standby mode, then press and hold the eject and stop button on the actual dvd player, the remote wont work doing this. this is how you can unlock and lock the dvds into the dvd player. why this is a feature jvc thought this needed im not exactly sure, but thats how you fix it.
JVC HR-XVC19S... | Answered on Feb 09, 2009
My 1st suggestion is to pull the AC power plug from the wall, wait 5 minutes (have a smoke or a coffee) and plug it back in.
Then retry the functions that are giving you grief.
Report back with the results and we'll go from there.
** Please re-comment if the suggestion did not work for you, there may be several other possibilities.
** Please add a comment before giving a rating Other than Solved
JVC HR-XVC19S... | Answered on Feb 06, 2009
Besides bounching this off a concrete wall for some satisfaction, try unplugging it for a couple of hours at least four hours and then plug it back in. Wait for it to stop loading and you may be able to watch one movie, two if your lucky before it starts flashing again. I've even sent mine to JVC for repair and got a year out of it but it's flashing again. This JVC item is the biggest piece of junk out there, if you read up on it it's had nothing but problems. Save yourself a lot of headaches and buy a new one and chock it up to experience.
JVC HR-XVC19S... | Answered on Jul 07, 2008
unplug the power cord from the back for 10 seconds
JVC HR-XVC19S... | Answered on Apr 01, 2008
HI Johnny,
Any chance someone went near the DVD/VCR and dusted with some Pledge or any kind of dusting spray? It sounds like something has got the DVD driver chip acting crazy. May be a faulty disc tray switch telling the controller the door is opening and closing all the time. If its brand new, do you have an opportunity to take advantage of a warranty claim?
JVC HR-XVC19S... | Answered on Nov 15, 2007
Use the App Search feature.
JVC Televison &... | Answered on Jan 19, 2020
Without a remote control, you can't.
JVC Televison &... | Answered on Jan 13, 2020
JVC HR-XVC19S DVD Player/VCR Logo
17 questions posted
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
jvc th a5r dvd digital cinema system
  • Televison & Video
