20 Most Recent
JVC DR-DX5 DVD/HDD Recorder Questions & Answers
The JVC DR-DX5 unit constantly
Good day!
If your DVD is says loading every-time you power ON it.
You have to do is to power off the DVD and open the cover.Next,reset all connectors inside the player by disconnecting and connecting again.After that power it ON again to test if it is OK.
If the problem persist I think the hard disc is failure.
Please try that simple instruction and I hope this will be helpful.Thank you.
Loading stays forever
First you do is to unplug the cord of your DVD unit for 5 hours in order
to drain the stored current,the purpose is to reset the unit. After the
5 hours plug the DVD see to it if it open If not,just try to press down
on the stop button and pressing eject button at same time and it will
unlock the tray .Then the other option is to open the cover of the DVD
unit and unplug the unit again to avoid electric shock . When open
already look for the disc platter moved it outward while driving the
gear or simply push out. The drawer or door of the DVD player and you
will see a small circular disc which is often called turntable or disc
platter.When the disc platter is out push it back and push it out you
do this three times so the slider mechanism align it properly.If you do
already what i said then plug it again and if works already closed the
cover. The slider mechanism, depending on the age of the unit and the
manufacturer, consists of the small chrome rail, a drive motor, a small
gear assembly, and (in some units) a small belt that drives the slider
unit via the motor. This small belt causes all sorts of problems. If
the belt is broken or slipping, it can cause skipping, dropouts, or
simply no start up at all. Also, if the belt breaks in the middle of
the disc, the drive mechanism gets hair or dirt wrapped up into the
gears, or the pick-up assembly doesn?t return to the start position
(called home), the unit will (99% of the time) refuse to release the
disc, causing it to become stuck inside the unit. There?s a little
micro or leaf type switch located at home position that sometimes gets
dirty or breaks and, causing this problem also. Hope it may help you;
Regards;
VOTIT
DONT FORGET TO RATE;
Please wait!
You can probably turn it off and back on and push the button really quick as it is coming on to get it to open and let you have the disc. Once it is open you might want to try blowing it out to make sure there isn't any dust in there. That could be causing the problem.
"please wait"!
Is there not a drawer open/close button?
Please wait usually indicated wrong type of disk and it is not being read or faulty laser.
Switch it off and switch on then press the drawer release before it starts trying to read.
JVC 43" (109cm) HD Ready Plasma TV PD43N30A. Chunghop universal remote codes for JVC pd43n30a
Question edited for a lot more clarity, plus
Chunghop not chungCHOP :>D
JVC: 089, 161, 909
CHUNGHOP Universal Remote Control Codes
codesforuniversalremotes.com
https://codesforuniversalremotes.com > chunghop-univer...
Jul 25, 2019 -
CHUNGHOP Universal Remote Control Codes ; Aiwa: 009, 057, 058 ; Samsung: 618, 619, 620, 621 ; Philips: 013, 023, 024 ; Hisense: 676, 677, 707, 898
My JVC TV has an onscreen remote that doesn't let us use the actual remote what do I do to gat it out?
Hello! If your JVC TV is displaying an onscreen remote and you're unable to use the actual remote, you can try the following steps to resolve the issue:
- Power cycle the TV: Turn off the TV and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. This can often reset any temporary issues and restore the functionality of the actual remote.
- Replace the remote batteries: Check the batteries in your remote control and make sure they have enough power. If the batteries are low, replace them with fresh ones and try using the remote again.
- Check the remote control sensor: Ensure that there are no obstructions between the remote control and the TV's remote control sensor. Clean the remote control sensor on the TV with a soft, lint-free cloth to remove any dust or debris that may be interfering with the signal reception.
- Reset the TV to factory settings: If the issue persists, you can try resetting the TV to its factory settings. Keep in mind that this will erase any personalized settings and restore the TV to its original configuration. Refer to the user manual or the manufacturer's website for instructions on how to perform a factory reset on your specific JVC TV model.
- Contact JVC customer support: If none of the above steps resolve the issue, it's recommended to reach out to JVC customer support for further assistance. They will have access to more specific troubleshooting steps and can guide you through the process of resolving the issue with the onscreen remote.
Keep in mind that the exact steps and options may vary depending on your specific JVC TV model. Refer to the user manual or contact JVC customer support for model-specific guidance.
JVC SR-DVM700U the front display is dimming quit low to where i cant read it
If the front display of your JVC SR-DVM700U is dimming to the point where it is difficult to read, there are a few potential causes and troubleshooting steps you can try:
1. Adjust the display brightness: Check if your device has a dedicated display brightness control. It could be a physical knob or a setting in the menu system. Increase the brightness setting to make the display more visible. Refer to the user manual for specific instructions on how to adjust the display brightness.
2. Check the power source: Ensure that the device is connected to a stable power source. If the power supply is fluctuating or inadequate, it can cause the display to dim. Try plugging the device into a different power outlet or using a different power cable to rule out any power-related issues.
3. Clean the display: Dust, dirt, or fingerprints on the display surface can also affect visibility. Gently clean the front display using a soft, lint-free cloth. Avoid using harsh chemicals or abrasive materials that could damage the display.
4. Check for backlight issues: The display might have a backlight that illuminates it. If the backlight is malfunctioning or failing, it can result in dimness. Unfortunately, in most cases, repairing or replacing the backlight requires professional assistance. Consider contacting a qualified technician or JVC customer support for further guidance and potential repairs.
5. Reset the device: Perform a factory reset on your JVC SR-DVM700U. This can help resolve any software-related issues that may be affecting the display. Consult the user manual or contact JVC customer support for instructions on how to perform a factory reset on your specific model.
If the above steps don't resolve the issue, it is recommended to reach out to JVC customer support or consult a professional technician who specializes in JVC audio/video equipment. They can provide further troubleshooting guidance or recommend appropriate repairs if necessary.
I have a jvc 40in model LT 40A 32C.THERE IS NO SOUND FROM SPEAKER OR EXTERNAL SPEAKER PORTS.
Here are some troubleshooting steps you can try to fix the sound issue on your JVC TV:
- Check the volume level: Make sure that the TV volume is not muted and the volume level is high enough to be audible.
- Check the connections: Ensure that the audio cables are properly connected to the TV and the external speakers. If you're using an external audio device, check its connections as well.
- Try resetting the TV: Turn off the TV and unplug it from the power source for a few minutes. Then plug it back in and turn it on.
- Check the audio settings: Access the TV's audio settings menu and ensure that the sound mode is set to "Stereo" or "Mono". You can also try changing the audio output settings to "TV Speakers" or "External Speakers" depending on what you're using.
- Try using a different audio device: If the above steps don't work, try connecting a different audio device to the TV to see if the sound works. This will help you determine if the problem is with the TV or the audio device.
If none of these steps work, it's possible that there may be an issue with the TV's audio hardware, and you may need to contact a professional repair service or the manufacturer for further assistance.
When I try to turn on my jvc projection tv the red light by the power button blinks 2 times and tv won't turn on?
The blinking red light on your JVC projection TV could indicate a problem with the TV's power supply, lamp, or other internal component. Here are some steps you can take to try to resolve the issue:
- Check the power cord: Make sure the power cord is plugged in securely to the TV and the power outlet. If the cord is loose or damaged, the TV may not receive the power it needs to turn on.
- Reset the TV: Unplug the TV from the power outlet and wait a few minutes before plugging it back in. This may reset the TV's internal system and resolve the issue.
- Replace the lamp: If the TV has been used for a long time, the lamp may be burnt out and need to be replaced. Check the owner's manual or contact JVC customer support for instructions on how to replace the lamp.
- Contact customer support: If none of the above steps work, the TV may have a more serious problem that requires professional repair. Contact JVC customer support for assistance or to find an authorized repair center in your area.
