20 Most Recent
JVC GR-D395 Mini DV Digital Camcorder Questions & Answers
How to transfer the video in Mini DV to my computer
I suggest getting the PCI IEEE 1394 also known as FireWire card. Most of the time these Firewire card comes with a Video editing software but verify because you will need some form of video editing s/w to record the video. After recording then you can edit it however you like and transfer to DVD/etc.
Always a pain in the as to edit video. I've done it a couple of times. So have fun. I still have not manage to find a Video editing s/w that will do a 5.1 audio or multiple audio tracks (similar to switching between languages)
What gig SD memory card
Your video camera supports SD and MMC cards according to the user manual but the card has to be of max. 2 GB. Any brand should be supported because it's a standard.
_how many gig is the
SD cards can come is various sizes, you should be able to read the volume on the card.
You can get up to 64 gig on a card but bear in mind not all cameras to use these newer cards.
The camera manual will tell you what size and speed is required for best operation.
Sound skips picture
Skipping sound is either dirty or faulty sound heads which are separate and apart from the Video heads, in a VCR.
You need to have the tape path and The Audio heads cleaned by a professional. Also they may need replacement, as this too is a sign of the audio heads failing.You need a professional to check to see.
Most head cleaning devices usually ONLY clean the Video Tape heads on the drum and NOT the audio, these need to be done by hand, this requires a professional. As usual always obtain a "Quote" before allowing any repair work to commence.
Jvc camera wont play back video , i keep hearing a
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
LCD shows stripes thus the picture is not complete
Mine was similar - with vertical black lines on playback. Visit Bristolcameras.co.uk, enter your make and model and ask for a head cleaner. They sent me one within 4 days and that was over the Christmas period. Reasonably priced too (£3.50 + p&p) and the whole head cleaner can be used up to twice once the tape has gone from beginning to end.
Jvc
I'm pretty sure you can. It should record about an hour on MPEG4 format.
Jvc gr-d395u video camcorder, move mini dv to computer
How it's supposed to work is to get a program that recognizes the camera, then the tape can be captures. Windows Movie Maker never supported it. In fact Microsoft doesn't even support it anymore. They have recommended using Pinncale Studio to work with DV cameras.
Once you install Studio, put the tape in, turn the camera on, Studio will load up.
Dv port broken
you need a fireware card to connect with pc maybe dv port is not broken
Why won't my digital camera charge via USB anymore?
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery.
Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
