20 Most Recent
Maytag MMV4205 Microwave Oven Questions & Answers
Maytag Microwave Oven (MMV4205AAW) won't power on.
You will need to replace the 20 amp.
ceramic fuse inside the unit. This is real easy and the fuse only cost around $10.00 You will find a break down of your unit at
www.partselect.com just enter your model number and a break down will come up. Your part number is PS2052772. You can also locate where the part goes. Good luck.
Hi. I accidentally ran
i personally do not recommend to a consumer to work on microwaves. they retain alot of voltage!
but will refer you here....
http://www.appliancepartspros.com/repair-help/maytag-microwave-mmv4205aaw-repair/mmv4205aaw-wont-start.html
I'm removing a Maytag microwave over stove model
Typically there is a metal mounting plate screwed to the wall and when you take the screws out of the cabinet above it it will tilt forward toward you and then you have to lift it off of some metal tabs that are on the bottom of that mounting plate. Lift up and pull away from the wall and let the cord pull out of the hole in the bottom of the cabinet. Good luck. I usually do that by myself and hook one arm under it and lift it up, but probably better with two people.
How do I change my MMV4205BAS to vent (recirculate) out of the front vent instead of the top vent.
Paul, if you look on top of the microwave before you install it you will see where the fan is located at the back edge. There should be 2-4 screws that hold it in place. Remove the screws and pull the fan up and out of the microwave and rotate the unit 90 degrees towards the front of the microwave and put it back in and replace the screws. That should be all that you have to do to get it to vent out the front.
