20 Most Recent Insignia IS-LCDTV32 32 in. Television Questions & Answers
I have a question? Do you move your Television frequently, OR do you unplug it frequently when it's not in use? I have found that doing either or both of those things can bring on problems, especially audio problems.
I've had the disappearing sound problem twice with my Element FLX-2610. This latest time I was stumped because the full scan didn't resolve the problem. And of course, the sparse manual that comes with the TV contains no troubleshooting advice at all.
But I did find a suggestion on another sveral other sites: Reset the TV. You might have a small reset button (like you would find on a DSL modem) somewhere on your TV but there is a manual way to do it two. Whichever way you do, MAKE SURE to disconnect every single device (yep, it's a pain) and UNPLUG the TV before doing this.
To reset with a reset button, disconnect devices and unplug the TV. Depress the reset button for 5 seconds. Reconnect devices, then plug in the TV.
Manual Procedure:
Disconnect all devices
Unplug the Television
Using the on/off button on the Television (NOT on the remote), depress and hold the button for 5 seconds.
Reconnect the devices, then plug in the TV.
Unless something has shorted out or burned up inside, this resetting, as a last resort, should fix the audio problem. Worked like a charm for me!
Good Luck!
Nena
Insignia... | Answered on May 18, 2019
A what stage does it fail to connect?
As general advise double check your wifi connections settings, that your wifi router is on and connected to the internet.
Insignia... | Answered on Mar 30, 2019
The size is #8-40 X 3/4". This is a specialty screw, so you're screwed
Insignia... | Answered on Jan 03, 2018
odd but the nation went totally digital several years ago .
Insignia... | Answered on Dec 06, 2017
Use audio out from the Tv box to CD input of your receiver and you should be able to hear sound then.
Insignia... | Answered on Nov 17, 2017
A manufacturer wont sell you LCD screens that big unless you are factory trained. There is nothing you can do with a bad LCD. Now you are in a bad spot because you can no longer dispose of electronic parts. They must be recycled. The recycling centers charge for those.
Insignia... | Answered on Nov 05, 2017
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Insignia... | Answered on Oct 07, 2017
No Sync indicates that the input signal doesn't match the type of signal that the TV can read. A digital source going to an analog input could cause the issue.
What is your source for the signal?
If you are using the DVI connection on the TV to connect to a computer, try using the VGA input instead. Unfortunately not all TVs can interpret the computer's digital signal. (It is different than the digital signal from a set top box.)
The manual for the TV is available from the product site: http://insigniaproducts.com/products/televisions/IS-LCDTV32.html . The direct link to the manual is: http://insigniaproducts.com/cms/documents/IS-LCDTV32%20UM%20EN_SP_FR.pdf .
Please add a comment with your source and I will offer additional suggestions for solving the error.
I hope this helps.
Insignia... | Answered on Sep 27, 2017
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Insignia... | Answered on Aug 08, 2017
Insignia... | Answered on May 18, 2017
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Insignia... | Answered on Apr 29, 2017
Insignia IS-LCDTV32 32 in. Television Logo
1,023 questions posted
Top Insignia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Insignia Televison & Video
Most Popular Question
not connect tv home wifi
  • Televison & Video
