20 Most Recent iLO 3200 32 in. LCD Television Questions & Answers
Hi, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. We have a few different codes for each of our different models of remotes. I will list here for you the best codes for a ilo TV for our more popular models of remotes and the instructions for addressing the remote to the TV. I hope this information is useful and if you have any further questions please let me know!
remote models remote codes
3.0, 3.1, 3.2, 3.4 IR remotes - codes 569, 720, 095, 743, 721, 500.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 569, 720, 128, 834, 729.
4.0 and 4.4 IR/UHF remotes - codes 720, 569, 500, 669, 549.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 569, 720, 500, 456, 506, 834.
20.0 IR and 21.0 IR/UHF remotes - codes 726, 559, 666, 596, 621, 596, 625.
Instructions for addressing the remote to the TV
1. Turn the TV on
2. Press and hold down the TV mode button until all the mode buttons light up red.
3. Enter the 3 digit code for you TV.
4. Press the pound(#) button once.
5. Try the TV functions to make sure it works.
iLO 3200 32 in.... | Answered on Feb 23, 2019
The sense of smell is a wonderful thing. Usually when you smell something burning and you shut it off quick enough it can be repaired. When you see plumes of smoke it's usually too late. If you have a reputable repairman he will be able to tell you if it's repairable or not. My gut feeling is, you should bury it in a quiet spot in the back yard. Sorry :(
iLO 3200 32 in.... | Answered on Dec 06, 2018
I got the same problem, TV stuck on one channel, what I did was, I remove the cable (fron the back) for a minute and then reconnect, work perfect, well, better than try to return the bloody thing.
Good look with your.
D.
iLO 3200 32 in.... | Answered on Apr 16, 2018
In used 10463 for my Direct tv remote...it is an Emerson code. It worked on my 27inch Ilo, from Walmart. Good luck.
iLO 3200 32 in.... | Answered on Jan 14, 2018
Check the tvs settings menu. There should be a HDMI sound option which will fix the delay.
iLO 3200 32 in.... | Answered on Nov 30, 2017
what kind of tv is it i work for fios and am willing to help you.
iLO 3200 32 in.... | Answered on Jul 13, 2017
there isnt a way and this is not a chat site
iLO 3200 32 in.... | Answered on Jul 01, 2017
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
iLO 3200 32 in.... | Answered on Mar 25, 2017
First of all, stop bitching about Wal-Mart. If they tell you there's nothing they can do, then there's nothing they can do. You shouldn't complain because you expect Wal-Mart to solve all your problems! 90 days is 90 days, after that they are not ALLOWED to take back your TV, and for those of you whom this pertains to, if it was messed up before 90 days, you SHOULD HAVE BROUGHT IT BACK IN TIME! Oh, and on the reciept piece, what don't you understand about that? How can they prove it's not stolen if YOU didn't save YOUR reciept?? Common sense says that you should have saved it. At any rate, the number you ned to call is 1-216-454-0867. Yes, it's long distance, get over it.
iLO 3200 32 in.... | Answered on Jul 12, 2016
I do beleive most tv companies stopped broadcasting over the air. the only way to receive more channels is to take the cable wire that comes out of the wall and then into the tv then auto pragram one more time and see if this helps. One question why would you remove the cable box? if you cancelled cable tv all together you will not get any channels. And like i said before all tv channels are removing there air broadcasting. so rabbit ears are going to be in the past soon. i hope this clarifies the situation.
iLO 3200 32 in.... | Answered on Apr 11, 2016
Greetings,
Give these a try. One should work for you.
007, 008, 011, 012, 017, 054, 033, 053, 065, 079, 168, 191, 192, 193, 194, 199, 250, 294, 296, 477.
Take Care,
-WN
iLO 3200 32 in.... | Answered on Mar 22, 2016
Tuner fault; suspected. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
iLO 3200 32 in.... | Answered on Dec 27, 2015
iLO 3200 32 in. LCD Television Logo
904 questions posted
Popular Products
Top iLO Televison & Video Experts
Ekse
Jerry Greenberg
Jerry Greenberg
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • iLO Televison & Video
Most Popular Question
ilo dpd4210 no picture or sound
  • Televison & Video
