Apex Digital Televison & Video • Uploaded on Aug 21, 2013
Your no disc error can be a DIY like the following
steps.
Assuming that the disc is good.
1.Clean the lens. -
Sometimes because of dust the lens can't read any disc. Try clean the lens by
soft cotton buds. Be careful while doing this.
I've suspect that you have a dirty lens,below are just for your guide.
2.Replace the ribbon - Check
the ribbon connected to the lens from the main board for scratch,
damage. Once it has an open line then of course the lens can't read the
disc. Also try to erase the contact by pencil eraser. If you've done the steps
above and the symptoms still there then the next step requires you a little
knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check
the motor that spin the disc with an ohmmeter. You can test it using the
ohmmeter (x1) even it is connected on the lens assembly.Good
motor - reading should be fairly high and it will spin. Bad
motor- reading will drop to low resistance and will not spin.
Hint : 50% of my
repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor
then replace it with a new one. Before replacing the new motor you have to
check the clearance of the disc holder with the old one. The clearance should
be the same as the old because if not the lens will not read the disc if it is
too far or too close.
Ifyou already cleaned the lens, and confirmed that
the ribbon is good as well as the motor then I've advice you to send it to
repair shop because the next step should be done with an expert because it is
quite technical diagnosing the fault between the pick-up lens and the main
board.
Give a thumbs up if you find it useful.
Have a nice day!
JDVillanueva
24 questions posted
193 Questions
97 Questions
59 Questions
