20 Most Recent
Xerox Phaser 850 Printer Questions & Answers
Timing, jams or prints off bottom of page
Hi hotpress:
Try these steps.
Print transfer jams
1. If a piece of paper is trapped in the paper preheater, try pushing out the paper by
inserting a stiff piece of cardstock into the paper preheater.
2. Using diagnostics, test the paper preheater sensors. If the test fails, replace the
paper/drum heater assembly.
3. Check to see if the upper feed roller drive belt is broken or slipped off of its pulleys. In
such a case, the upper feed roller does not rotate when the lower feed roller rotates.
4. Check that the feed rollers rotate smoothly and that the front cover is fully closed and
seated.
5. Check the paper-eject path for obstructions. Ensure no small pieces of paper are
trapped around the stripper fingers or rapid release guide.
6. Ensure that the transfix roller rotates during the transfix process. See SF168 and
SB467.
7. Test the sensors in the paper path. Look for damaged or non-operating sensor flags.
8. Check the transfix solenoid and its cam. Ensure they operate correctly and are properly
lubricated. If lubrication is needed, apply a dab of grease to the contact point between
the cam and the latch and the cam and the cam-advanced spring. Refer to
"Lubrication" on page 6-177.
9. A stripper finger, or rapid release guide, jam can occur because of broken teeth on the
small section of the back-side of the compound gear. The root cause of this may be also
be due to a lack of transfix cam grease. If you find broken teeth on the compound gear,
check for proper lubrication of the transfix cam. Be careful to ensure that no grease
touches the Y-axis belts. If the belts get contaminated with grease they must be
replaced. wipe off any excess grease to prevent it from dripping onto the belts.
Hope this helps
