20 Most Recent
Maytag MEW6530DDS Stainless Steel Electric Single Oven Questions & Answers
Oven is slow to heat up and will not heat above 250
You may have a bad heater coil in the oven or have lost a leg in the 220 line. Check and reset the breaker 1st then check the voltage in the receptacle. It should be 110 from each leg to ground and 220 across the hot legs.
1/4/2015 2:26:57 AM •
Maytag...
Answered
on Jan 04, 2015
Front Panel Buttons not responding
The touch control panel is a piece of ****! Call MAYTAG, and get a new one, you should still be under warranty. Make them send you the part direct ( its the WHOLE front top panel ), then call a tech to put it in for $50 bucks. Takes about 10 minutes to do. The panel plugs into the electrical Board behind the panel.
FYI...the Top panel includes the Stainless Panel + the Touch controls! Its all one integrated part. The part that goes bad is the "cable contacts" that latch to electrical panel.
FYI....the Cable is made of "thin clear film " similar to Film you put in a Camera.
4/16/2014 8:24:37 PM •
Maytag...
Answered
on Apr 16, 2014
Only some of the keys on the keypad of my oven
Hello, Thank You for using FixYa. I will be helping you today.You didnt have to change the computer you need to replace the control panel. The control panel is the whole front piece which has the touch membrane on it. This is common on these units.
Thank You and please rate my answer if it was helpful..
1/26/2012 2:29:38 PM •
Maytag...
Answered
on Jan 26, 2012
How do I replace a
Hello, Thank You for using FixYa. I will be helping you today. Pull the oven out a few inches turn the power off. You will see two screws on each side of the control when you pull it out remove them. Then take off the control panel you will see the high limit about mid way back. Thats it..
6/21/2011 1:51:56 AM •
Maytag...
Answered
on Jun 21, 2011
I have a Maytag in wall oven (part# MEW653ODDS).
HI. This will be the actual control board in this case, that will be the culprit. the control board, and touch pad, are integrated. These symptoms are indicating that the key pad membrane is damaged. This will require you to replace the entire control board. Once the control is replaced, these issues will be corrected.
6/10/2011 1:24:29 AM •
Maytag...
Answered
on Jun 10, 2011
How do I get the
Unfortunately your going to have to call a service tech out, unless you have a programming manual.
10/10/2010 10:32:17 PM •
Maytag...
Answered
on Oct 10, 2010
