20 Most Recent eMachines E525 D260 Motherboard MB.N7602.001 / MBN7602001 Questions & Answers
Try to boot it from safety mode.
and try to restore your system first.
If the restoring is failed, boot safety mode again and back up your files.
If you can't boot your laptop from safety mode, use anti virus program CD like norton.
Mostly, your system is messed up by adwares, spywares, and virus.
If all things fail, you should check your HD.
If you need further help, reach me via phone at https://www.6ya.com/expert/hee_458d01a29d21e0d3
eMachines E525... | Answered on Sep 04, 2014
Make sure your installing the right windows either 32 or 64 bit windows.you can't install a 64 bit system on a 32 bit if it doesn't support it.
eMachines... | Answered on Oct 26, 2019
microsoft has a license type called OEM which detects the computer that it is installed on and some computers have the licence key stored in the bios of the computer.
So when you grab the old hard drive and put it in the next computer Windows will detect you changed computers and not run as per OEM licensing rules that it runs on only the original purchased computer.
You might be able to run the drive as a secondary drive but you would need to install a new windows operating system and hard drive. And then use a partioning program to make the secondary drive not an active drive.
also you new machine most likely has a different type of bios called EFI
and you would have to change its settings to run AMI Bios but I do not think that is your problem as I think it is OEM but it might be worth investigating if you can run a legacy bios in the bios settings.
eMachines... | Answered on Oct 05, 2019
Hi there. If your desktop has been overheating for any reason you will need to look at buying a new processor (cpu), power supply (if wires have been damaged from heat or voltage spike), or possibly a new motherboard. It would be advisable to have a computer shop look at the internal components of your desktop. Heat or a surge in power can damage the computer hardware. Good luck!
eMachines... | Answered on Apr 09, 2019
hello and good morning.
emachines are old and now owned by acer.com (gateway,etc)
they OWN many old names.
you are running XP right? the last man on earth to do so?
XP is a virus magnet and doomed, it is time to upgrade.
this PC is 2007 made. so is 12 years old, today..
the RTC coin cell battery will be no good now, replace it for $2
then reset BIOS inside BIOS screen " set default"
then test the HDD, to be sure it is ok, if not? then reloading any OS of any kinds is not going to work with any bad HDD.
Last, reload a new OS.
there are the steps. and can be expensive, spent on any PC this old with zero street value. ($0 if broken a it is)
eMachines... | Answered on Apr 01, 2019
http://www.emachines.com/ec/en/US/content/drivers.html
eMachines... | Answered on Mar 02, 2019
Examine the rear panel carefully to find it.
eMachines... | Answered on Feb 02, 2019
You'll have to unsolder the entire battery holder and replace it with a new one. Not suggesting you try it unless you have the proper desoldering equipment. Otherwise, damage to the motherboard will result
eMachines... | Answered on Nov 04, 2018
sorry no idea what you have as not listed in question . but WHY are yo letting a 3 yr old get it anyway .
eMachines... | Answered on Nov 23, 2017
eMachines E525 D260 Motherboard MB.N7602.001 / MBN7602001 Logo
2 questions posted
Top eMachines Computers & Internet Experts
Thomas F. Schneider
Ekse
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • eMachines Computers & Internet
Most Popular Question
emachines e528 laptop won 39 t start
  • Computers & Internet
