20 Most Recent
ViewSonic NextVision N3260W 32 in. HD-Ready LCD Television Questions & Answers
I need a working viewsonic code for my innovage remote.
Programming procedure is too much to type in here, and is not practical. If you wish to get more details, check the sites linked
here. Set-up code list, and Set-up
procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to
Mosaic
/ Timeslide, can be selected by the
drop-down list, at the top left
of the display window, will make surf easy. You can also do a
search, by type in the
brand name of your TV / Device, in the search box
at the top right of the display window.
11/10/2013 7:04:20 AM •
ViewSonic...
Answered
on Nov 10, 2013
Viewsonic n3260w will not turn on no green light and I have check the plug ,cord and power at the wall
Good day!!!!That problem is usually cause of faulty capacitors on the power supply board..Just follow this instruction to fix your TV..1. Open the back cover of your TV.2. Look at the power supply board..Its normally connected to the power cord..3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..5. Some of the capacitors not bulged so its better if have a capacitance meter
7/11/2012 3:30:42 PM •
ViewSonic...
Answered
on Jul 11, 2012
Tv will not start!
It is
If the red light is blinking it is indicating an error or fault to the unit but the common fault of the lcd is the power supply. Try to remove the back cover of your tv then try to look for bulge up capacitor or leaky capacitor. The bulge up capacitor is that the top is not perfectly flat like the others and the leaky capacitor has a wet mark at the bottom of the capacitor. This faulty capacitor cause a unfiltered dc output and it cannot transfer dc output properly to distribute dc voltage to other parts of your tv. If you are not handy in electronics and not familiar with the electronic parts I suggest that you should contact a technician to do it for you and save you from stress. feel free to send feed back good day and best regards. Note before opening the back cover be sure to unplug the unit.
8/12/2011 10:39:22 AM •
ViewSonic...
Answered
on Aug 12, 2011
Replaced backlight inverter, tv came on for less
Check the fuse on the tv power supply board,replaced the fuse it is near the A/C socket for the A/C power cord to plug it into.Replacing fuse.If still have no power all,than the whole power supply board it is shorted out.The tv power supply board must have be replace to make the tv to work again.
8/10/2011 2:51:24 PM •
ViewSonic...
Answered
on Aug 10, 2011
I have a Viewsonic
The problem of your tv is in the power supply. In order to find the power supply of your tv ,you should follow the ac cord. But first you should unplug the unit and open the back cover of your tv there you will find the power supply, try to check the capacitors, it is cylindrical shape and has a plastic cover. Try to observed if their is a wet mark or oil mark that spread in to the pcb then replace it. But when replacing the capacitor you should observed the polarity of the capacitor and replace it exactly the way you pulled it out.
6/6/2011 12:13:28 PM •
ViewSonic...
Answered
on Jun 06, 2011
My Viewsonic n3260w has no
The tv T-CON board only board left could causes this problems.That the board usally sit at the middle at the botton of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
3/22/2011 6:15:42 AM •
ViewSonic...
Answered
on Mar 22, 2011
Power light flickers no other sign of power n3260w
If you get a flicker of power light then your problem is in your power supply, I would check for bulging capacitors and replace, if you don't find any then replace power supply, you can check places like shopjimmy.com, or discount-merchant.com or with an s, vancebaldwin.com
2/1/2011 11:25:23 PM •
ViewSonic...
Answered
on Feb 01, 2011
