20 Most Recent Toshiba 17HLV85 17" LCD HD TV/DVD Combo Questions & Answers
Screen on toshiba tv 17hlv85 shows a green line on right side
contact manufacturer the panel is bad. flat rate usually.
6/2/2009 3:19:57 AM • Toshiba 17HLV85... • Answered on Jun 02, 2009
Toshiba 42RV500E sound issue
This is a known issue with this TV. The following might resolve it: Check Mute and Volume: Ensure that the TV is not muted and that the volume is set appropriately. Sometimes accidental button presses can lead to muted sound or low volume. Inspect External Speakers: If you're using external speakers, verify their connections. Loose cables or faulty speakers can cause sound issues. Test Different Inputs: Connect a non-HDMI device (such as a DVD player) to the TV. Observe if the sound distortion occurs. If it doesn't, the problem might be related to the HDMI signal from your Virgin box. HDMI Troubleshooting: If the issue persists with the DVD player over HDMI, consider the following: HDMI Cable: Check the HDMI cable for damage or loose connections. Virgin Signal: Contact Virgin to inspect the signal/lines and replace the box if necessary. Mainboard Replacement (if needed): If the sound distortion persists, it could be due to a faulty sound processor chip on the TV's mainboard. In this case, consider replacing the mainboard. TOSHIBA 42RV500E, 42RV500T, 42RV500Y, 46RV500E, 46RV500T User Guide (manualmachine.com)
4/7/2024 11:34:38 AM • Toshiba... • Answered on Apr 07, 2024
Toshiba 72HM195 has started getting red streaks
There may be loose contact or track open in main board.So try to check the main board thoroughly where you may find the loose of connection or track open.
3/25/2024 5:27:53 AM • Toshiba... • Answered on Mar 25, 2024
Change batteries on my toshiba se-r0001 remote
  1. Locate the Battery Cover: Look for the battery cover on the back of the remote control. It is usually a small compartment that can be easily opened.
  2. Remove the Battery Cover: Depending on the design, there may be a latch, screw, or sliding mechanism to secure the battery cover. Use your fingers or a small screwdriver to open the compartment.
  3. Remove Old Batteries: Take out the old batteries from the battery compartment. Pay attention to the orientation of the batteries, so you know how to insert the new ones correctly.
  4. Check Battery Polarity: Take note of the positive (+) and negative (-) signs inside the battery compartment. Make sure to insert the new batteries with the correct polarity to match these markings.
  5. Insert New Batteries: Place the new batteries into the battery compartment, ensuring they are properly aligned with the correct polarity. Press them down gently to make sure they are secure.
  6. Replace Battery Cover: After inserting the new batteries, close the battery compartment cover securely. If it has a latch or screw, make sure it is fastened properly.
  7. Test the Remote: Point the remote at the device it controls (such as a Toshiba TV) and test whether it responds to your commands. If the remote is working correctly, you have successfully replaced the batteries.
  8. Dispose of Old Batteries: If the old batteries are no longer usable, make sure to dispose of them properly. Many communities have designated recycling locations for batteries.
3/9/2024 3:29:56 AM • Toshiba... • Answered on Mar 09, 2024
I need a manual for my Toshiba 2010 tv serial # A10A13799C3300
Serial numbers don't work Judy https://www.google.com/search?q=A10A13799C3300 They are purely a numerical identifier of when it was made, year, day, number on the shift, whether it Joe or Billy who did final inspection. With a MODEL number I can find them easily with just 'make model manual'.
Owner's Manual
Toshiba http://www.toshiba.com > support > content PDF Thank you for purchasing this Toshiba LCD TV. This manual will help you use the many exciting features of your new LCD TV. Before operating your LCD TV, please. 62 pages
Owner's Manual - Integrated High Definition LCD Television
Toshiba http://www.toshiba.com > support > content PDF Thank you for purchasing this Toshiba LCD TV. This manual will help you use the many exciting features of your new LCD TV. Before operating your LCD TV, please ... 62 pages ..
3/2/2024 7:58:53 PM • Toshiba... • Answered on Mar 02, 2024
Toshiba GR-AG66MA-XK Inverter Refrigerator suddenly not cooling. Display (eco & quick freeze) keep blinking non stop.
This is somewhat experimental technology, although all fridges are basically inverters. The link suggests all sorts of things. https://www.google.com/search?q=Toshiba+GR-AG66MA-XK++eco+%26+quick+freeze+keep+blinking+non+stop ..
2/27/2024 7:12:55 AM • Toshiba... • Answered on Feb 27, 2024
Can I program a insignia remote NS-RC03A-13 to a Toshiba tv
No you can't the Insignia remote is for that model television only. Companies don't make their remotes so they operate other makes of televisions. Buy a Copy Remote for the Toshiba https://www.google.com/search?q=insignia+remote+NS-RC03A-13 ..
2/18/2024 7:20:13 PM • Toshiba... • Answered on Feb 18, 2024
Need a manual for Toshiba SE-R0295
That appears to be the model number for the remote control. You need the manual for the television. https://www.google.com/search?q=toshiba+se-r0295+manual ..
1/22/2024 11:59:30 PM • Toshiba... • Answered on Jan 22, 2024
Toshiba 47" flatscreen. Power up
The information provided suggests that there might be an issue with the main board of the electronic device. However, it's important to consider a few factors before deciding to replace the main board:
  1. Check for Error Codes or Diagnostic Signals: Some devices have error codes or diagnostic signals that can provide more specific information about the issue. Check the device's manual or documentation for any error codes or signals associated with the flashing LED or other symptoms.
  2. Perform a Hard Reset: Before replacing any components, try performing a hard reset on the device. This involves turning off the power, unplugging the device, and waiting for a few minutes before plugging it back in and turning it on. Sometimes, this can resolve temporary glitches.
  3. Consult Manufacturer Support: Contact the manufacturer's customer support or refer to the product's support resources. They may be able to provide troubleshooting steps specific to your device and guide you on whether a main board replacement is necessary.
  4. Professional Inspection: If you are not familiar with electronic repairs, consider consulting a professional technician. They can inspect the device, run diagnostics, and provide a more accurate assessment of the issue.
  5. Check Warranty: If the device is still under warranty, replacing components yourself may void the warranty. Check the warranty terms and conditions before attempting any repairs.
  6. Consider Other Factors: The issue might not solely be with the main board. Power supply issues, faulty connectors, or other components could contribute to the problem. A thorough inspection can help identify the root cause.
If, after considering these factors, you still believe that the main board is the likely culprit and you are comfortable with the replacement process, you can proceed with replacing it. However, exercising caution and exploring all available troubleshooting options is advisable before making any decisions.
1/17/2024 8:35:42 PM • Toshiba... • Answered on Jan 17, 2024
Please looking for a service manual for service code tv Toshiba 49l621U, main board SBB55T VTV L55730. Thanks.
Question edited for clarity and toss in some CAPS. Unfortunately there is no service manual online, you just replace boards. https://www.google.com/search?q=toshiba+49l621u+service+manual+pdf ..
1/4/2024 8:00:29 PM • Toshiba... • Answered on Jan 04, 2024
Toshiba 49L621U 49-Inch 4K LED Ultra HD TV. Looking for a Service Manual please?
Question edited for a lot more clarity and toss in some CAPS. Unfortunately there is no service manual online, you just replace boards. https://www.google.com/search?q=toshiba+49l621u+service+manual+pdf ..
12/10/2023 10:55:18 PM • Toshiba... • Answered on Dec 10, 2023
Toshiba TV, sound works but no picture I have a Toshiba 49L621U. It was made in September 2016. When I turn it on, I see “ Toshiba” in big bright red letters (normal startup image) than the TV goes black. The sound works and I did the flashlight test and I see a very very dim picture when I get up close. Can anyone tell me what part I need to replace and what the part number is? Thanks in advance.
Same issue here. I kept plugging in the TV and it would flash the logo and go black. I disconnected the LED line from the power board, plugged the TV back in and the LED's all lite up and got great picture. Turned it off and on a few times with the power switch with no problem. Left it alone about an hour, came back, got the same symptoms all over again, Flash then nothing. I changed out the Power Supply board....same issue, Flash of logo and black screen. Probably going to heave ho the set.
12/5/2023 7:51:06 AM • Toshiba... • Answered on Dec 05, 2023
Codes for a Toshiba VC-755 remote?
This is a single standalone Remote to 7 models of Toshiba DVDs. It is not a Universal Remote. https://spencertified.com/products/toshiba-vc-755-tv-vcr-remote-control-remote-spencertified this OEM remote to replace your old one. It is the original factory remote for Toshiba VCR Model as well as others, and is ready to use without ANY setup. It comes with a 6 month warranty that covers all costs if it becomes defective, the peace of mind that you are purchasing this from the best source for vintage electronics and batteries!
THIS REMOTE WAS ORIGINALLY SUPPLIED WITH THE FOLLOWING MODELS...
  • M725
  • M725C
  • M735
  • M755
  • M755C
  • M775
  • W755
If you need a Universal Remote, read this https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
11/12/2023 4:12:02 AM • Toshiba... • Answered on Nov 12, 2023
Toshiba DVR620KC player. It won't turn on.
It needs professional service. Something has failed internally, probably capacitors. https://www.google.com/search?q=Toshiba+DVR620KC+not+working ..
9/29/2023 7:49:15 PM • Toshiba... • Answered on Sep 29, 2023
Replacement DVD Read/Writer for Toshiba RXV59DTKB
Refer to troubleshooting section (page 1-11-1) of service manual ManualsLib - Makes it easy to find manuals online!
9/23/2023 5:53:28 PM • Toshiba... • Answered on Sep 23, 2023
I have a Toshiba DVD recorder problem reading disc
You did not specify the exact model. However error code given on page 171 on Error Codes On The Display Window - Toshiba RD-XS34SU Owner's Manual [Page 171] ' ManualsLib manual may help.
9/23/2023 5:53:20 PM • Toshiba... • Answered on Sep 23, 2023
Toshiba 23HLV87. No picture or sound
It seems power supply section of TV become defective.
9/21/2023 5:00:59 PM • Toshiba... • Answered on Sep 21, 2023
I have a Toshiba DVD recouder DR430KU
Please refer to page 93 of user manual TOSHIBA DR430KU DVR OWNER'S MANUAL ' ManualsLib
9/19/2023 11:47:31 AM • Toshiba... • Answered on Sep 19, 2023
Toshiba mod#65l621u.flashing red light 5times
Check or replace batteries, power cycle the TV, maybe TV is reloading and installing new update or firmware, if nothing helps, call Toshiba tech support
8/29/2023 8:41:07 PM • Toshiba... • Answered on Aug 29, 2023
I need a manual for the Toshiba ct90121 remote control please
The directions for programming a television remote like the CT-90121 will be in the manual for the TV that it came with. One such model is the Toshiba 36HFX72. The manual for this TV is available at ManualsLib here: https://www.manualslib.com/manual/172528/Toshiba-32hfx72.html#product-36HFX72 . The directions for using the remote starts on page 14, https://www.manualslib.com/manual/172528/Toshiba-32hfx72.html?page=14#manual . The remote control programming directions start on page 17. The device codes start on page 19. Please note: universal remote code lists are usually limited to devices that were programmed 6 months or more before the universal remote was programmed. Since the 36HFX72's manual has a copyright date of 2002, the CT-90121 may not control devices built in late 2002 or later. I hope this helps. Cindy Wells
8/28/2023 11:54:44 PM • Toshiba... • Answered on Aug 28, 2023
Toshiba 17HLV85 17" LCD HD TV/DVD Combo  Logo
2 questions posted
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
screen toshiba tv 17hlv85 shows green
  • Televison & Video
