20 Most Recent Maytag MZD2667HE Side by Side Refrigerator Questions & Answers
Can't change dispenser selector
seems defective control panel in front of fridge
12/6/2013 8:43:58 PM • Maytag MZD2667HE... • Answered on Dec 06, 2013
0answers
Not cold enough
HI. DEFROST ALL FIRST 24/48 HOURS AND TRY.if it works then check your defrost timer first and then heater and t/stat.then next stage .good luck ali
7/9/2012 11:17:23 PM • Maytag MZD2667HE... • Answered on Jul 09, 2012
Maytag model MZD2766GEW. The water tube supplying
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
6/28/2011 6:50:23 PM • Maytag MZD2667HE... • Answered on Jun 28, 2011
Running to warm
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
4/3/2011 5:37:19 PM • Maytag MZD2667HE... • Answered on Apr 03, 2011
I installed the new filter but the red light is
On the refrigerator side: Open the door and press the light switch in and out 5- times so you can reset the computer, do this quickly. If this fails, try unplugging the refrigerator for a minimum of 5-minutes. Plug unit back on after 5-minutes- this should reset PC.
10/5/2010 3:07:51 AM • Maytag MZD2667HE... • Answered on Oct 05, 2010
Maytag wide by side MZD2667HEW freezer works fridge does'nt
Was it the damper control you replaced and it's still not adjusting the vent(damper)? And is the cold air from the freezer being blown through the vent by the fan in the freezer.
The circuit board mainly controls the defrost timing and the fans. I don't know that it would solve your problem.
9/21/2009 3:00:49 AM • Maytag MZD2667HE... • Answered on Sep 21, 2009
Shelf removal
turn it around or upside down
9/20/2009 12:59:40 AM • Maytag MZD2667HE... • Answered on Sep 20, 2009
Freezer doesn't work , fridge does. Side by side
Well if the fridge is cooling fine and freezer is not working, you have one of the following faults:-
1.defrost thermostat.
2.defrost timer.
3.defrost heater.
Please check these to resolve the issue.
Thanks!
mannu_rakesh
9/1/2009 4:33:28 PM • Maytag MZD2667HE... • Answered on Sep 01, 2009
How do you install maytag "mbb1954g" ice maker plastic water line connection to the freezer?
To connect the water supply using a plastic hose kit to the MBB1954G UNIT, you can follow these steps: Turn off the water supply valve under the sink. Remove the old hose from the water supply valve and the back of the refrigerator. Attach the new plastic hose to the water supply valve and the back of the refrigerator. Make sure the hose is not kinked or twisted. Tighten the fittings with an adjustable wrench. Turn on the water supply valve and check for leaks. Here is a video tutorial that demonstrates how to install a water line to an ice maker or refrigerator using a 5 foot hose with 1/4 inch compression fittings. INSTALLING ICE MAKER / REFRIGERATOR WATER LINE - using 1/4" compression hose (youtube.com)
2/15/2024 9:40:38 PM • Maytag... • Answered on Feb 15, 2024
Maytag 2 door fridge has only water for ice cubes. Is there a water filter for the ice?
you can add water filter. It is installed on supply line. go to Home Depot and pick up a refrigerator water filter kit with accessories.
10/19/2023 1:58:54 PM • Maytag... • Answered on Oct 19, 2023
I got some ice from the doors ice and water dispenser I heard the ice maker turn over then instead of water going into the ice maker to refill it began coming out the door water dispenser.
inspect the ice make to check for any sign of visible damage or misalignment, .and unplug the fridge and plug it again
8/23/2023 5:17:05 PM • Maytag... • Answered on Aug 23, 2023
Where is the defrost timer on Maytag top freezer RTD21E0CDL
Matthew...you sure you have the Model# right? Cuz Google comes up with Zip..Zilch with that #.? :)
8/15/2023 5:37:38 PM • Maytag... • Answered on Aug 15, 2023
My Maytag MZD2768GE frezzer side is forming ice on the bottom. Water is coming out of the lower vent.
Fridge/freezer freezing up- and no fan or air circulation: first check the defrost terminator thermostat it may have gone out. Thus not allowing the heating element to melt the ice. AT TIMES The fan usually stops working AND CAN MAKE FUNNY NOISES AS WELL due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature. May also need to check the defrost timer, The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. Or in the fridge compartment near middle top section. u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad? Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next. Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance.. Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS . Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit? ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area! THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 1300 ( give or take 150 ohms) ohms is required Freezer /fridge leaking water/ice frozen in fridge and or freezer, or leaks on floor Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out. Fix any gaps in the door seal.Pack out the seal underneath the areas where the door seal has the gaps. This can be done with a small strip of weather stripping, as shown here, or a bit of tightly rolled up paper under the door seal. Alternatively, you can heat the door seal up with a hair dryer to fix the gaps. This softens the door seal and allows you to stretch it. Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor. However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick. Another trick one can use is to connect a copper tube wire with one end going into the drain hole then attach the other end to the heater wrap it around heater a few times. That will take care of the drain problem when it comes to ice build up but not food build up. Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also. Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer. God is so good: so this is why I give free advice so please thank him not me. OTHER THINGS TO CHECK ARE THE DEFROST TERMINATOR AND THE HEATER ELEMENT FOR COBNTINUITY. defrost timer location defrost terminator-undefined-undefined-0_2.jpg door seals cracked-fridge-seals-undefined-undefined-1.jpg drain center drain holer-undefined-undefined-2.jpg drain hole freezer downside-undefined-undefined-3.jpg evaporator-fan-blade.1280x600-undefined-undefined-4_0.jpg
7/26/2023 8:07:17 PM • Maytag... • Answered on Jul 26, 2023
Does the Maytag Model: MSD2651KES have a drip pan underneath?
The Maytag Model MSD2651KES is a side-by-side refrigerator. It does not have a traditional drip pan underneath like some other refrigerator models. Instead, it uses a drain system to collect and channel condensation and defrost water. The condensation and defrost water from the freezer section of the refrigerator typically flow down through a drain hole and into a drain pan or trough located at the bottom of the refrigerator. This drain pan is usually not accessible from the outside and does not require regular maintenance or emptying. If you are experiencing any issues with water leakage or pooling around your Maytag refrigerator, it is recommended to check the drain system for any blockages or clogs. Ensure that the drain hole is clear and that the water can flow freely through the system. If you suspect a problem with the drain system, it is advisable to consult the refrigerator's user manual or contact Maytag customer support for specific guidance on troubleshooting and resolving the issue.
6/28/2023 2:44:00 AM • Maytag... • Answered on Jun 28, 2023
Oil coming from the inside of my Maytag refrigerator door?
Either the compressor is broken or is now compromised.The compressor needs to now be replaced for your fridge.
5/10/2023 7:12:14 AM • Maytag... • Answered on May 10, 2023
2answers
Water pooling at bottom, how do I find out why?
Water is pooling at the bottom of your refrigerator because the drain in the freezer is clogged, probably with ice. You need to turn of the refrigerator and empty the freezer. Remove the cover in the bottom of the freezer by first removing the back cover of the freezer and then the bottom cover. You will probably see it full of ice. Remove this ice by chipping, or if you have time, let it thaw. Then, located the drain in the back of the compartment below the coils, and thaw it. You can use a hair dryer for this. Eventually, you will see the water drain, and you can dry everything up and put it back together. You should have no more problems. If you do, then you need to look at testing the defroster.
4/24/2023 3:40:07 AM • Maytag... • Answered on Apr 24, 2023
Maytag MZD2667HE Side by Side Refrigerator Logo
Popular Tags
20 questions posted
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Refrigerators
Most Popular Question
running warm
  • Refrigerators
