20 Most Recent Toshiba 56HM195 56" Projection HDTV Questions & Answers
Toshiba DLP Horizontal lines across bottom half of the screen
Time for a new set
12/14/2017 9:38:12 PM • Toshiba 56HM195... • Answered on Dec 14, 2017
2answers
Mitsubishi 52525 dlp flickering horizontal lines problem
You must replace the main board.
11/12/2017 1:48:00 AM • Toshiba 56HM195... • Answered on Nov 12, 2017
0answers
0answers
Toshiba 72hm195.how do i enter service menu
With the set ON, press MUTE once remote, then press MUTE again and hold in down while pressing MENU on the TV The letter S will appear on the screen to show that the set is in the Service mode To select the adjustment that you want to change press CH+ or CH - Press VOL+ or VOL- to adjust
10/9/2013 5:22:27 PM • Toshiba 56HM195... • Answered on Oct 09, 2013
Mitisubshi projection tv starts horazonal
the digital board has surface mount ic's that have cold solder joints, resolder with hot air resoldering station. make sure you don't overheat them!.......................meder's tv service
10/3/2013 5:33:08 PM • Toshiba 56HM195... • Answered on Oct 03, 2013
Lamp problem
IF NOT A TOSHIBA REPLACEMENT BUT A GENERIC LAMP THAT COULD BE THIS SET'S PROBLEM.Other than that the Ballast that fires the Lamp may be the problem.Note: if lamp only lasts several months there is another possible reason: Some of these sets had a setting in the customer menu for something like "quick on"===if your set has this and it is engaged the lamp never completely shuts off--this feature was so you did not have to wait when dead cold and off for twenty some seconds after turn on for the picture to appear.Problem with this is when you turn set off lamp dims but does not go out and fan may shut off quickly that should cool the lamp when set is turned off.Other than looking in the menu with a working lamp watch where lamp is when you turn the set off---it should go out almost instantly and the fan for the lamp should run about 3-5 minutes and then it should turn off.It was a nice but stupid feature that a lamp running all the time affects your electric bill and really shortens the life of the lamp, most of us with remote start on our car will not leave it running 7-24.
12/15/2012 5:43:12 PM • Toshiba 56HM195... • Answered on Dec 15, 2012
I have a toshiba 50 hdx 82 it has a distorted picture with pink and green halos
The Scaler Digital board is going out in your set. You will need to contact your local toshiba service center
8/13/2012 10:58:11 PM • Toshiba 56HM195... • Answered on Aug 13, 2012
Toshiba 56hm ic repair
The model listed here 56hm195 is a dlp and has no ic's for this issue.Double check the model number on the rear of the set and let me know--if convergence the set will have a way in the menu to attempt to adjust--if it has that the model indicated is wrong.
4/4/2012 9:41:20 PM • Toshiba 56HM195... • Answered on Apr 04, 2012
My 56HM195 Toshiba tv does not turn on, I replace
do you have power light ?or any thing
4/4/2012 8:13:24 PM • Toshiba 56HM195... • Answered on Apr 04, 2012
I have a toshiba 56Hm 195 only half has picture
a PROBLEM likely to be either in the optical light engine or a separate digital board in the set---engine is more likely and a very expensive part not to mention labor.
3/18/2012 4:56:15 PM • Toshiba 56HM195... • Answered on Mar 18, 2012
Toshiba 56HM195 56" Projection HDTV Logo
Popular Tags
72 questions posted
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
lamp problem
  • Televison & Video
