20 Most Recent Maytag MCD2257HE Side by Side Refrigerator Questions & Answers
Why is Maytag refrigerator MFI2568AE keypad frozen?
Perhaps the fridge is working too hard? this can be caused by a defective thermostat. Buy a cheap thermometer (should be go as low as - 30 or -40 Celsius ) put it in the fridge. The freezer is working ok, if the temp is around -18. The fridge should be between +5 and +7. If one or both are much lower, change the setting and watch if it helps (can take a day or so) if it does not change, I think someone should put in a new thermostat. Sometimes there is a switch you can use when you want the freezer to work hard, because you need to freeze some fresh food. If that switch is still engaged, switch it off. It only costs lots of energy if it is below -18, and is not keeping your food one day longer in good condition.
6/25/2014 1:29:26 PM • Maytag MCD2257HE... • Answered on Jun 25, 2014
What would cause the freeze to be cooling normally
all it does is the freezer gets cold,the evap fan blows cold air from the freezer into the fridge section so if the freezer is fine,check the air ducts in the fridge section,if a package or something is blocking the vent on the bottom it will get warm or also on your model you have a damper on the top where the air blow into the fridge section from the freezer,you have an electronic damper,there's a door that opens and closes to let the air in,when it's cold enough the door closes when it gets warm the door opens so either the damper is bad or the computer board that operates it is bad,also check the packages in the freezer,if you see frozen water droplets on the packages or ice on the shelves the door could have been left open and the air ducts freeze so no air can pass through,you can hit the air ducts with a hair dryer to melt them out but be careful,don't keep the heat on one spot for to long,you can damage the ducts,also when you open the freezer door you should hear the fan blowing,if not you could have a bad evap fan motor and the air isn't blowing over to the fridge section,the damper is like 45 dollars and the computer board is around 120 dollars,you can go onto the sears site,put your model number in and look at the controls and you can look up the parts.http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MCD2257HEB/3048/0165000/M0703130/00006?blt=06&prst=&shdMod= copy and paste.open the freezer door,listen for the fan no fan bad motor,if the fan is blowing either the air ducts are frozen or you have a problem with the damper or board that operates the damper,you might want to call in a tech for this if it is the damper,it's a little tricky to do this job but that's up to you.good luck and i hope this helps you out.
9/24/2011 4:23:45 PM • Maytag MCD2257HE... • Answered on Sep 24, 2011
I'm getting water in the ice dispenser. The
First, check to see if the evaporator fan is blowing in the freezer. A common cause for this problem is an air baffle that is stuck open, or closed due to frost buildup or a component failure. The air baffle is at the top of the wall between the freezer and the refrigerator. If you check for cold air coming through this vent, you will probably find that it is constantly open. A temperature sensor (thermistor) in the refrigerator normally detects temperature and a control board sends voltage to a motor to open and close this baffle properly to control refrigerator temperature. You could have a failed thermistor, failed baffle motor or a failed control board that is causing your problem as well.
7/27/2011 5:11:45 AM • Maytag MCD2257HE... • Answered on Jul 27, 2011
Our Maytag side by side
Tgere might be several different problems but let me suggest that you try this first. If you haven't cleaned the coils, do so now! Unplug your refrigerator, using a long brush, twirl the bristles over the coils and pull the brush out. Continue doing this until no more dust/debris is left in the area of the coils. This will help to accommodate evaporation so that the coils can do their work cooling your Refrigerator.You can purchase special refrigerator brushes at most hardware/home improvement stores. If you are diligent about cleaning the coils, then you may have a more serious problem. I hope this helps. If it does, please rate me on Fixya. Good luck!
12/13/2010 6:13:14 AM • Maytag MCD2257HE... • Answered on Dec 13, 2010
Freezer section works but the refrigerator side is
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
5/24/2010 4:16:27 AM • Maytag MCD2257HE... • Answered on May 24, 2010
Icemaker malfunction in Maytag refrig
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Model is always helpful when requesting information.
8/26/2009 2:00:00 AM • Maytag MCD2257HE... • Answered on Aug 26, 2009
Maytag refrigerator, feezer side coil frozen and frigirator not
Defrost circuit failed, needs to be able to defrost the coils so air can pass through them thus cooling evenly. You can check the heaters located on the coils probably near the bottom back wall of the freezer with a ohm meter if you read through, the heaters are good, if you get no reading the heaters are bad. Or could be defrost timer or on newer models the adaptive defrost control which is a circuit board. If its an older model you can manually turn the timer with a screwdriver if you feel resistance, then you should replace the timer. Also in the circuit is the defrost thermostat located on the coils, this is the least expensive of the 3 components to replace. You should have a schematic located under the fridge, use this to determine which type of timer you have and for further trouble-shooting. Please let me know if this helps
8/22/2009 5:44:18 PM • Maytag MCD2257HE... • Answered on Aug 22, 2009
The water dispenser on our Maytag sideby side
IS THERE A WATER FILTER ON UNIT....???...CHECK INCOMING WATER PRESSURE AND VOLUME AT SUPPLY TO UNIT.SADDLE VALVES DO GET PARTIALLY PLUGGED IF INCORRECTLY INSTALLED.
8/15/2009 5:01:08 PM • Maytag MCD2257HE... • Answered on Aug 15, 2009
Click and a loud whining noise
check fan on inside of freezer unit. also check fan on back of fridg on lower bottom
8/12/2009 3:44:25 AM • Maytag MCD2257HE... • Answered on Aug 12, 2009
Maytag sidebyside refrigerator, refrigerator side
I WOULD INCREASE THE TEMPERATURE SETTINGS TO A HIGHER SETTING. Oh ABOUT THREE OR FOUR DEGREES SHOULD BE ENOUGH
7/19/2009 4:09:52 PM • Maytag MCD2257HE... • Answered on Jul 19, 2009
Vacuumed my coils in my side by side, but the
which motor? compressor, condenser mtr next to the compressor or the mtr inside the frzr?
first chk to see if the fan mtr inside the frzr is running, if mtr is runnnig, then you have a problem w/compressor or relay loacted on compressor. alot of those compressor are locking up for no reason and maytag has a RECALL notice on their refrigs. contact maytag to see if your model is effected.
7/16/2009 3:35:38 AM • Maytag MCD2257HE... • Answered on Jul 16, 2009
How do you install maytag "mbb1954g" ice maker plastic water line connection to the freezer?
To connect the water supply using a plastic hose kit to the MBB1954G UNIT, you can follow these steps: Turn off the water supply valve under the sink. Remove the old hose from the water supply valve and the back of the refrigerator. Attach the new plastic hose to the water supply valve and the back of the refrigerator. Make sure the hose is not kinked or twisted. Tighten the fittings with an adjustable wrench. Turn on the water supply valve and check for leaks. Here is a video tutorial that demonstrates how to install a water line to an ice maker or refrigerator using a 5 foot hose with 1/4 inch compression fittings. INSTALLING ICE MAKER / REFRIGERATOR WATER LINE - using 1/4" compression hose (youtube.com)
2/15/2024 9:40:38 PM • Maytag... • Answered on Feb 15, 2024
Maytag 2 door fridge has only water for ice cubes. Is there a water filter for the ice?
you can add water filter. It is installed on supply line. go to Home Depot and pick up a refrigerator water filter kit with accessories.
10/19/2023 1:58:54 PM • Maytag... • Answered on Oct 19, 2023
I got some ice from the doors ice and water dispenser I heard the ice maker turn over then instead of water going into the ice maker to refill it began coming out the door water dispenser.
inspect the ice make to check for any sign of visible damage or misalignment, .and unplug the fridge and plug it again
8/23/2023 5:17:05 PM • Maytag... • Answered on Aug 23, 2023
Where is the defrost timer on Maytag top freezer RTD21E0CDL
Matthew...you sure you have the Model# right? Cuz Google comes up with Zip..Zilch with that #.? :)
8/15/2023 5:37:38 PM • Maytag... • Answered on Aug 15, 2023
My Maytag MZD2768GE frezzer side is forming ice on the bottom. Water is coming out of the lower vent.
Fridge/freezer freezing up- and no fan or air circulation: first check the defrost terminator thermostat it may have gone out. Thus not allowing the heating element to melt the ice. AT TIMES The fan usually stops working AND CAN MAKE FUNNY NOISES AS WELL due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature. May also need to check the defrost timer, The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. Or in the fridge compartment near middle top section. u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad? Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next. Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance.. Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS . Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit? ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area! THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 1300 ( give or take 150 ohms) ohms is required Freezer /fridge leaking water/ice frozen in fridge and or freezer, or leaks on floor Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out. Fix any gaps in the door seal.Pack out the seal underneath the areas where the door seal has the gaps. This can be done with a small strip of weather stripping, as shown here, or a bit of tightly rolled up paper under the door seal. Alternatively, you can heat the door seal up with a hair dryer to fix the gaps. This softens the door seal and allows you to stretch it. Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor. However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick. Another trick one can use is to connect a copper tube wire with one end going into the drain hole then attach the other end to the heater wrap it around heater a few times. That will take care of the drain problem when it comes to ice build up but not food build up. Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also. Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer. God is so good: so this is why I give free advice so please thank him not me. OTHER THINGS TO CHECK ARE THE DEFROST TERMINATOR AND THE HEATER ELEMENT FOR COBNTINUITY. defrost timer location defrost terminator-undefined-undefined-0_2.jpg door seals cracked-fridge-seals-undefined-undefined-1.jpg drain center drain holer-undefined-undefined-2.jpg drain hole freezer downside-undefined-undefined-3.jpg evaporator-fan-blade.1280x600-undefined-undefined-4_0.jpg
7/26/2023 8:07:17 PM • Maytag... • Answered on Jul 26, 2023
Does the Maytag Model: MSD2651KES have a drip pan underneath?
The Maytag Model MSD2651KES is a side-by-side refrigerator. It does not have a traditional drip pan underneath like some other refrigerator models. Instead, it uses a drain system to collect and channel condensation and defrost water. The condensation and defrost water from the freezer section of the refrigerator typically flow down through a drain hole and into a drain pan or trough located at the bottom of the refrigerator. This drain pan is usually not accessible from the outside and does not require regular maintenance or emptying. If you are experiencing any issues with water leakage or pooling around your Maytag refrigerator, it is recommended to check the drain system for any blockages or clogs. Ensure that the drain hole is clear and that the water can flow freely through the system. If you suspect a problem with the drain system, it is advisable to consult the refrigerator's user manual or contact Maytag customer support for specific guidance on troubleshooting and resolving the issue.
6/28/2023 2:44:00 AM • Maytag... • Answered on Jun 28, 2023
Oil coming from the inside of my Maytag refrigerator door?
Either the compressor is broken or is now compromised.The compressor needs to now be replaced for your fridge.
5/10/2023 7:12:14 AM • Maytag... • Answered on May 10, 2023
2answers
Water pooling at bottom, how do I find out why?
Water is pooling at the bottom of your refrigerator because the drain in the freezer is clogged, probably with ice. You need to turn of the refrigerator and empty the freezer. Remove the cover in the bottom of the freezer by first removing the back cover of the freezer and then the bottom cover. You will probably see it full of ice. Remove this ice by chipping, or if you have time, let it thaw. Then, located the drain in the back of the compartment below the coils, and thaw it. You can use a hair dryer for this. Eventually, you will see the water drain, and you can dry everything up and put it back together. You should have no more problems. If you do, then you need to look at testing the defroster.
4/24/2023 3:40:07 AM • Maytag... • Answered on Apr 24, 2023
Maytag MCD2257HE Side by Side Refrigerator Logo
21 questions posted
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Refrigerators
Most Popular Question
maytag refrigerator feezer side coil
  • Refrigerators
