20 Most Recent Toshiba Satellite A105-S4004 Notebook Questions & Answers
The laptop screen flickersand turns grey, it also
You could try using compressed air to clear out the fan, but most likely your system is overheating and the longer you go without fixing it the worse and more permanent issues it will cause
11/17/2017 4:19:46 AM • Toshiba... • Answered on Nov 17, 2017
0answers
0answers
Backlight repair for p845t-s4305
You will want to take this into a local PC repair shop to have them repair this; Not all PC repair shops do this type of work. If you want to do this yourself, look up the backlight part number based on your model of laptop, and order the backlight.
12/10/2013 4:07:08 PM • Toshiba... • Answered on Dec 10, 2013
Wifi settings not find wireless connection
make sure your wifi router is broadcasting so you can find it from your laptop. you may need the pass-phrase if you have that turned on. also, check your laptop to make sure the wifi radio is turned on. this is usually a button on the side or a function key on your keypad.
10/26/2013 9:42:50 PM • Toshiba... • Answered on Oct 26, 2013
Keep losing internet connection
Recommendation: If you can switch from the 3rd party wireless utility to the Windows utility. There should be a check box under the properties that says, "Let Windows manage my connection." Also turn off any power management that stops your drives, suspends the machine, etc. When doing WEP, use the actual key, not your password. i.e. the one that looks like "aaff996753bc" not "rosebud".
Reason: Windows wireless starts before you even log in and loads as a service, it runs whether your logged in or not, sleep mode, etc. 3rd party utilities...especially my personal bane of all wireless devices "Netgear" load as applications. That means they don't initialize until after log in and they can be suspended completely or prioritized by power management and resource management utilities when the machine is idle. As for the key thing... WEP translation with Linksys especially can be a little funny with some wireless so I use the key itself which always works.
8/6/2013 1:20:28 PM • Toshiba... • Answered on Aug 06, 2013
PXE-E61: Media test failure, check cable
As far as I know this is common error on toshiba laptops when OS is not installed or corrupted. Try removing hard drive (look at guide or on youtube) and reconnecting, if error still ocurrs, then reininstall os if you have windows cd (need to download drivers as well from Toshiba's site.)A new hard drive is fairly inexpensive, from eBay (refurb.is fine)
2/6/2013 2:35:23 PM • Toshiba... • Answered on Feb 06, 2013
2answers
Laptop upgrade
What can I upgrade in a laptop? Below is a listing of common laptop upgrade questions and the answers to each of the questions regarding laptop and portable computer upgrades.
Laptop questions and answers CH000618, What can I upgrade in a laptop? CH000780, How do I clean my laptop? CH000917, My PC Card (PCMCIA) does not fit in my laptop.
Computer questions and answers listing 900 - 1000 CH000910, Determining what type of memory to use in a memory upgrade.
Save to file / partition information. In addition, if your laptop did not support PHDISK or HDPREP unless there is an available BIOS update you cannot upgrade to PHDISK or HDPREP.
Hope theses links can be helpful for ya, read and follow instructions.
Good Luck, Please dont for get to Vote/Thank you.Merry Christmas
12/13/2012 11:35:41 PM • Toshiba... • Answered on Dec 13, 2012
2answers
Toshiba Satillite A105
Send it back to geek squad and have them correct the issue.
12/2/2012 11:55:34 PM • Toshiba... • Answered on Dec 02, 2012
3answers
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. [email protected] for any additional questions.
10/23/2012 6:28:33 AM • Toshiba... • Answered on Oct 23, 2012
2answers
Toshiba satellite A105-S361
the inverter maybe going bad. go to ebay get a cheap toshiba satellite a105 lcd inverter.bam the problem fix oh you would need a screw drivercause this is a diy project no need tosend it out link me if anything [email protected]
7/21/2012 11:32:27 PM • Toshiba... • Answered on Jul 21, 2012
My laptop will not power on
the battery could be too low to power it or the power park is bad or the battery is total bad or the chager is not in good condition.
2/23/2012 7:06:55 AM • Toshiba... • Answered on Feb 23, 2012
My toshiba spa10 displays a
Are you getting into OS after that ??
Usually there would be a welcome screen for all laptops which gives directions to go to BIOS,Select Boot device,etc..
Probably in BIOS you will have an option to set the dely of your welcome screen as well.
Let me know if this helps you.
Regards,
Sreejith
8/4/2011 8:20:53 AM • Toshiba... • Answered on Aug 04, 2011
I'm not sure where the
The memory card slot is at the front of the laptop just beside the 2 audio ports (for that purpose you have to remove the card from the adapter). Hope this helps.
6/13/2011 9:08:03 PM • Toshiba... • Answered on Jun 13, 2011
Cd is not recognized
hey
first check wheather other cd are reading or not if not then ur cd romm is not working properly check the drivers of ur laptop and after insertng cd select the option on cd drive select open/expore
then ur cd will open
if not working inform
6/10/2011 6:40:28 PM • Toshiba... • Answered on Jun 10, 2011
Toshiba Satellite A105-S4004 Notebook Logo
Popular Tags
155 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
toshiba satellite a135 screen flicker
  • Computers & Internet
