20 Most Recent Toshiba Satellite A85-S107 Notebook Questions & Answers
Buen dia. Mi proble es
Hola Manuel, al parecer cuando regresastes todo a su logar cambiastes algo y ahora es un poco complicado componer este mal funcion, te envio un video que puedes tener una idea de las mediciones que es necesario hacer para determinar el problema, usualmente nosotros podemos ayudar virtualmente cuando se trata de software o configuracion, ya cuando es un asunto mecanico se utilizan metros para hacer mediciones.
5/17/2019 7:07:07 AM • Toshiba... • Answered on May 17, 2019
I need to wipe the hard drive of my Toshiba Satellite A85-S107 and reinstall Windows XP without the Windows install discs. I have tried holding down the "zero" button, per instructions on the net, bu
you might want to try restarting the computer and as soon as you see the Toshiba logo on the screen start pressing F1. if that doesn't work try again and this time press F8. look for an option that says something like restore this computer. im not sure this model has a recovery partition. if it doesn't you'll probably need to get your hands on a Windows XP disk. you could ask a friend with a dell computer they may have their disk. or you could try a flea market. but before you erase your computer you need to make sure you have your coa sticker on the compter still. it looks like the sample im providing. if you have any questions feel free to ask.
3/3/2017 5:58:17 AM • Toshiba... • Answered on Mar 03, 2017
Activate blue keys
Hold down the FN key while pressing the blue keys... ;-)
8/3/2015 9:12:55 AM • Toshiba... • Answered on Aug 03, 2015
Resource conflict pci motherboard
Set your bios to default. It might fix the problem.
5/24/2014 4:38:23 PM • Toshiba... • Answered on May 24, 2014
0answers
Keyboard replacement
Hello this is for uprading the memory , But does show how to remove the keyboard
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A85/replace-laptop-memory-1.htm
Good Luck .Joe
10/29/2013 11:00:37 PM • Toshiba... • Answered on Oct 29, 2013
2answers
My toshiba wont boot past the BIOS screen. What
Several things could be wrong, the most likely is a failed HD or damaged windows install. If you press F12 it should take yuo to the boot menu, reply back with the list of options and I'll take a look,
Chris
1/29/2013 1:23:53 AM • Toshiba... • Answered on Jan 29, 2013
2answers
How can i restore my Toshiba A85 Satellite Laptop
Without the recovery disks you will pretty much need to find someone with an OS Disk to reload your laptop. If you know someone with a dell computer they might have a disk you can borrow and reload your laptop that way. I have found it Dell disks to be alot more easier to use when reloading a different makers computer. You will also need to use another computer to download the drivers for your toshiba onto a stick drive so you can be up and running.
Or you can take it into a repair shop and have them do the work which should only cost around an hours worth of labor.
Best of luck..
9/24/2012 9:02:53 AM • Toshiba... • Answered on Sep 24, 2012
Part # hinges a-85 s-107
Go to www.ebay.com type make and model of laptop, refine search to hinge, also try www.toshiba.com contact customer support.
8/6/2012 5:40:39 PM • Toshiba... • Answered on Aug 06, 2012
The WIFI is not working on my laptop.
Let's start with updating your wireless drivers.
You can find them here:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1042296&rpn=PSA82U&modelFilter=A85-S107&selCategory=3&selFamily=1073768663&selModel=1042296%7CPSA82U#
Let me know if this fixes the problem, otherwise I'll suggest something else.
Best of luck!
5/20/2012 12:32:50 AM • Toshiba... • Answered on May 20, 2012
One key fell off
You should be able to place it on the retainer and press it on, you may need to move it around a bit. If it just flat won't snap back on, check the retainer to make sure that the pins that fit into the clips on the back of the key aren't bent or broken, and check the clips on the key to see if the sides are bent or broken. If the pins or sides of the clips are bent, take a small flathead screwdriver and straighten them. If they're broken it will need to be replaced.
4/23/2012 8:34:54 PM • Toshiba... • Answered on Apr 23, 2012
How do I change a keyboard on a satellite A85-S107 laptop?
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.2. Remove those screws with a T-8 or Phillips screwdriver.3. Turn the laptop back over and open it up. Check and see if the Toshiba Satellite A85-S107 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.4. Remove the plastic pieces carefully.5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.7. Take the new Toshiba Satellite A85-S107 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.8. Refasten the keyboard in place at the top.9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.10. Turn the laptop over and replace all of the keyboard screws.11. Put the laptop battery back in place and switch it on to check Toshiba Satellite A85-S107 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
3/14/2012 9:51:10 AM • Toshiba... • Answered on Mar 14, 2012
2answers
A85S107 Toshiba Laptop: Laptop will
If you are sure that it's not the fan in question then you'll need to check the heat sink could be too much or too little thermal compound
9/5/2011 6:08:52 PM • Toshiba... • Answered on Sep 05, 2011
Bios does not detect cd
I have a Toshiba Satellite L355D that would not detect the CD Rom in the BIOS although the Rom appeared to powered up and running. I traced the problem to a ribbon cable connector that was between the jack the CD Rom plugged into and the jack on the mother board. The ribbon cable plug at the MB had backed out and was only making the power connections to the Rom making the Rom appear to be operating.
8/24/2011 7:52:43 PM • Toshiba... • Answered on Aug 24, 2011
Want to reset my bios setup password for my A85 toshiba laptop. Which jumper need to be reset
you need to open the back cover of your laptop so that you can access the motherbaorad..ther u can see  a CMOS battery ..just remove it and after 20 sec ..put it back..it will reset th BIOS password...
8/11/2011 7:21:30 AM • Toshiba... • Answered on Aug 11, 2011
Sound worked for at least
Here are some steps which you can try.
- Restart the computer if the computer if you haven't restarted it yet. - Perform system restore back to the earliest restore point. - Reinstall the sound card driver if above steps don't work.
Hope this helps.
6/5/2011 4:27:53 AM • Toshiba... • Answered on Jun 05, 2011
Toshiba Satellite A85-S107 Notebook Logo
130 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
change keyboard satellite a85 s107
  • Computers & Internet
