20 Most Recent Toshiba Satellite A105 Notebook Questions & Answers
2answers
Ntldr is missing on toshiba satellite a105 series laptop
u have toreapir your win xp with recoery disk.
8/8/2021 1:13:44 PM • Toshiba... • Answered on Aug 08, 2021
Cannot open internet when trying to get wifi
Ok - few things to clarify first:
When you say "it connects" what do you mean? Do you open internet explorer and can browse the net without problem?
You Pick up Wifi connections - make sure you pick the correct one to connect to and ensure that you use the correct Password.
If all the above are working then make sure the Laptop is rebooted when you attempt to connect to wifi. Msn has problems when it can not resolve correct IP address - rebooting the machine should fix that.
Or the connection speed is too slow - which these days can still happen.
Finally, Get the full error message from msn and type it into google. Guide yourself to the Microsoft pages with the correct solution.
So few things to clarify and few things to test out.
I hope this helps, don't forget to rate my solution.
Thanks.
3/19/2021 12:03:52 PM • Toshiba... • Answered on Mar 19, 2021
Not audio toshiba A105A
you will need to reinstall the audio device driver.  go to toshiba.com and download the device driver for your machine.
10/30/2020 12:01:20 PM • Toshiba... • Answered on Oct 30, 2020
3answers
ITunes not able to burn CD's
you already have other cd / dvd burner software on pc / laptop...use it...(can i suggest a better software than itunes for burning..unless you have this already..nero, ashampoo and / or burn4free cd / dvd)...nero has much more to place on the menu of dvd...cd (u can get creative)....this way your new version of itunes will just keep your ipod up to date (no more regs problems)
3/28/2020 6:41:55 AM • Toshiba... • Answered on Mar 28, 2020
Can't see cursor
for future reference, Disconnect the mouse and plug it back in. It may need a new mousemouse
12/15/2018 11:28:09 AM • Toshiba... • Answered on Dec 15, 2018
Toshiba satellit a45 owners manual
You can find the manual for Toshiba Satellite A45 on the link mentioned below: http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su587690/satellite_a40_ug_20031113.pdf GuruAid.com
11/26/2018 8:45:30 AM • Toshiba... • Answered on Nov 26, 2018
2answers
I have a Toshiba NB250
I would suggest a factory restore to fix the problem. If you have data on the computer that needs saving then do this first, if unable to do this then take to a computer shop to have it done for you.
11/14/2018 11:22:04 AM • Toshiba... • Answered on Nov 14, 2018
Toshiba A105 lcd problems?
Sounds like the ribbon is misplaced, try to place it correctly a few times and see if you can get it to sit right.
10/25/2017 7:18:32 AM • Toshiba... • Answered on Oct 25, 2017
0answers
2answers
When I turn the laptop
Dear beanbean,This "lovely black screen" is a BIOS password screen. This shows up because somebody has set a boot-up password in the BIOS Setup. If you're lucky, the BIOS Setup is still unprotected, and you can access it as follows:When you turn it on, look for something that says "Press [button] to enter Setup" or "Press [button] to enter Setup Utilities." Press the corresponding button on your keyboard, and you should enter BIOS Setup. Now two things can happen. Either you are permitted to access Setup, or you are prompted for the password.If you can access Setup, navigate to the Security tab and clear all set passwords.If not... then you can either reset BIOS by unplugging the computer, taking off the back, and removing the CMOS Battery (unrecommended), or you can call Toshiba support and ask for the master password (Most manufacturers have a master password, which will allow you to access Setup and remove the boot-up password)Hope this helps,Ericthecmh
12/7/2015 6:22:17 PM • Toshiba... • Answered on Dec 07, 2015
How do i unlock my bios password on a blue screen i forgot it
disconnect the cmos battery or reset it with the jumper
9/23/2015 7:28:29 PM • Toshiba... • Answered on Sep 23, 2015
When I type letter keys, numbers come up with the letters
That's because some are dual function keys; you've probably hit the 'Alt' or 'Fn' key to the bottom left of the keyboard by accident. If you look carefully at the letter keys, they should have numbers on them in a different colour/smaller text.
4/5/2015 5:13:20 PM • Toshiba... • Answered on Apr 05, 2015
How do i take a
1. Open a program called"Camera Assistant." This is a Toshiba-supported computr program designed specifically for people with cameras built into their laptops.You can find this by clicking on the "Start" menu and then navigatingto the "Programs" sub-menu. 2. Press the"Picture" button in the "Camera Assistant" program windowto take a picture using your built-in camera. This will take one stillphotograph for every time you click the button. The image you are taking willappear on the right side of the main program window. 3. Press the"Video" button in the "Camera Asst" program window tobegin recording video using your built-in camera. This will record video untilyou press the "Stop" button. The video you are recording will appearon the right side of the main program window. 4. If you can't open"Camera Assistant," reinstall your drivers. Though the camera on aToshiba laptop is designed to work right out of the box, if it doesn't you mayneed to reinstall the driver that makes it work. Look for the CD labeled"Drivers and Software" that came packaged into the box with yourToshiba laptop. Pop it in your laptop's CD-ROM or DVD-ROM drive and install the"Digital Camera" driver contained on the disc.
3/18/2015 12:55:36 AM • Toshiba... • Answered on Mar 18, 2015
Toshiba locked asking for password
turn on, press F2 key to enter Setup. in Setup either cancel password (under Security) or choose Default Settings to cancel the password.
1/31/2015 8:08:25 PM • Toshiba... • Answered on Jan 31, 2015
2answers
The 17.1' display of my toshiba satellite P105 its
Just a quick note, before you go replace the entire screen, make sure it's not just a wiring problem. If so, it doesn't cost as much to replace the wires connecting the screen to the laptop. LCD's are much more expensive!
As for replacing the display, this website has information on the display, along with the ability to purchase it from their site. http://www.pelltechnology.com/Toshiba/Laptop/Toshiba-Portables-Satellite-P105-Series-S6024/Toshiba-Satellite-P105-S6024-LCD-Screen-Replacement-P350475.asp
Hope this works!
1/13/2015 12:58:59 AM • Toshiba... • Answered on Jan 13, 2015
How do I reset the BIOS password on a Toshiba satellite A105?
Tap the restart or turn on the computer, soon as you turn on the computer, tap the f12 button until you get to the pat were it said delete and reboot. And just reboot. That will delete old passwords an delete everything and bring it back to factory default
12/14/2014 2:06:13 AM • Toshiba... • Answered on Dec 14, 2014
Toshiba a45 -s120 owners manual
The manual is located here. Satellite A45 S120 Support Toshiba
11/29/2014 12:26:39 PM • Toshiba... • Answered on Nov 29, 2014
Toshiba Satellite A105 Notebook Logo
1,332 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
restore factory settings satelite a75
  • Computers & Internet
