20 Most Recent
Toshiba TDP-T90 Multimedia Projector Questions & Answers
Toshiba TDP-T90 projector, lamp
is lamp cover closed firmly-is power cord good(try with another cable)-is power fuse ok!!!-is power supply ok.and gives normal rating output voltage as a the book say.all previous will check first befor lamp and fan.
Projector will only stay on for a couple of
Make sure the venting for the cooling fan is clear and that it is activating. The only time I have seen this in a projector is when it overheats. If it reaches a certain temperature and doesn't sense the cooling fan being on it shuts down to protect the bulb and protect against fire hazard.
Toshiba tdp-t90 projector. I rplaced the lamp on
set the beamer off, unplug the power line, press -on-/input/menue at the same time and plug the beamer to the power line again thereafter you can remove your fingers from the below mentioned buttons. now the lamp counter should be reseted to 0 hope this helps it works on a TDP-T100
Hello there
Not sure if the
Vibrating fan requires lubrication on its shaft, drop little thin machine oil and hope problem will be solved, for time being.
Correct solution is to replace that fan.
Thanks.
No power
the power supply is bad and needs replacing. the capacitors dry out after a while on this model.
Problem with power point
These devices get hot when they work. they need cooling. if the cooling system get dirty and fan cant turn clearly then it stops itself for protection. it need to be cleaned.
hope it works
