20 Most Recent HP 2x1x16 Kvm Ip Switch 16 Port 410530-001 408965-001 Questions & Answers
op, and older HP DESKTOP only 0 years old today 2011
your question lacks a question.
the word hOW TO , too hard to type? IDK, only can I guess you r meanings.
the answer is simple. power cord pulled from wall. AC wall jack.
1: mount the new drive in the HDD cage in side.
2:plug in HDD power cable from PSU.
3: plug in HDD SATA cable from SATA port to HDD.
4: power on PC, and in disk manager assign it a drive letter and format it. bingo works now. that simple,
the service manual stinks,
looks link no drive bay HDD2, there.
looks like no extra power cables for 2nd HDD, if you have no need for DVD , use those 2 cables will work, and if a SSD
recommended, just tie warp the SDD to the case bar just above the existing HDD.
there are no IDE PATA Drives, here per Andrew.
HP does show w10.64bit support, wises.
this PC is 100% SATA drive PC, ! not year 2000- IDE.
HP Computers &... | Answered 2 hours ago
hey,
try to press the power button for a forced shut down(maybe 10-15 seconds). then remove the battery. press the power button again, hold it for like 1 minute, release. put the battery again in, and now try a normal power on.
HP Computers &... | Answered 3 hours ago
whats the windows os version? if you can go to bios settings then you can disable the Smart card Authentication.
HP Computers &... | Answered on Jan 17, 2020
NO PC stated at all nor OS you run, windows 10?
a monitor can be connected to vast things made, non stated.
Using it on PC desktop or laptop or as TV monitor? IDK..
connected how?
(1) DisplayPort 1.4 (1) HDMI 1.4 (1) USB Type-C there is no camera in this monitor,. but no full model told.
some may have one. but all 3 HP guides on it show none..here
https://support.hp.com/us-en/product/hp-pavilion-27-inch-displays/7274719/manuals
zilch cam .
HP Computers &... | Answered on Jan 11, 2020
that is not one projectors its many models none stated.
nor what HP Laptop of 1000's of models.
sanyo pro xtrax = projector ,
using and adaptor, non stated, no answers possible
tell what is on both ends
video ports. and get real answers.
if one end is vga or DVI there will be no sound on those ports period.
DP and HDMI yes. but what projectors have speakers,? sure some do but not yours.
but why not use the laptops sound or the line out jack 3.5mm
to an external power speakers.
what PC model
what exact projector
no stated, no answers possible.
if that old Laptop like mine, it has VGA out, and is no sound on the jack ever. (just internal or using line out to real powered speakers. mine is EliteBook.
you didn't say.
HP Computers &... | Answered on Jan 05, 2020
OK w7, you added that thanks.
well , dim features are complex on laptops
I bet it does not stay dim in BIOS screens
the F1 info screen, so...
but does only in windows running, right?
The PC autodims the screen for 2 reasons (by design)
a battery weak. or setup to run dim when on battery only mode, in windows power settings,
reason 2, the screen camera is used to see when the room is dark, if yes, it dims. this to is a a setting in power settings of windows.
click start, click control panel,click power icon.
click advanced, see "power" settings
you will discover many things are (on battery do X)
all laptops with windows, set it as you want.
http://www.pcdied.com/sleep-or-dim.html
also laptops dim if you move the pc from say bright window open (sun filled room)
to a dark room it is a feature on vast laptops
to save battery power, and also dims if the battery is weak or bad. all do that.
and last reload the drivers on you PC
at hp.com
go to hp, click support, then go to your PC find the drivers and load them for Windows 7, only at HP, nowhere else. ok?
recap:
1: dark room PC dims. (auto room dim can be turned off)
2: battery dead, or bad or weak, it dims . on purpose
3: bad w7 drives or screen Grapics chip GPU.
HP has em'
4: corrupted OS, win7 is infected. f11 reload time.
5: screen has CCLF black lamps as all do 2009 and older and all are dim now or dead. or purely random and ddeath soon for the CCLF tubes.
2012 PC this is and is LED so not CCFL but we do always look 2010 and back (age)
HP Computers &... | Answered on Jan 04, 2020
There is no reset button. What are u trying to do?
27 ER you meant? a new monitor?
er27
PLUGGED IN TO WHAT? you posted to computers , IS IT .?
NO OS stated running windows 98?
what port used, vga,dvi,dp, hdmi cable.
no adaptors? on cable either end or inside cable.
we can not see what you have before you eyes.
it must be told first.
ALSO , no screen content stated. at all
windows desktop not filling screen?
or using say VLC running old DVD 4:3 video.
that will always not fit modern wide screens.
what is on your screen , what is there, exactly even a photos works 10x better posted.
NO PC stated
no OS stated
NO screen content stated, doing what seeing what/
HP Computers &... | Answered on Dec 29, 2019
if you press the + and - buttons on the front of the monitor at the same time for 10 seconds it disable's it. You can disable it completely by running the software disc and choosing disable Theft Lock.
HP Computers &... | Answered on Dec 26, 2019
Now I am browsing through https://everybookmakers-ke.com in search of a decent betting website and I wanted to ask you guys for an opinion. Which one is better?
HP Computers &... | Answered on Dec 23, 2019
Complete the following steps to set up your wireless mouse.
  1. Make sure your computer is turned on. ...
  2. Remove the battery compartment cover on the bottom of the mouse, insert the battery, and then replace the cover. ...
  3. Turn on the mouse. ...
  4. Connect the USB receiver to the USB connection on your computer.
More items...
Setting up the HP Wireless Mouse x3000 ' HP® Customer ...
https://support.hp.com > product > hp-x3000-wireless-mouse > document
Videos as well
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ACYBGNRTNf57iCTkk_0V3KquuY9EUvJ00w%3A1576983617495&ei=Qdz-XaH_HYfYsQWY8I_ADg&q=hp+wireless+mouse+how+to+connect
HP Computers &... | Answered on Dec 22, 2019
Check what format are the files are you trying to open with GOM player.
his are the extension can be opened by GOM:
.go, .avi .svi, .divx, .asx, .asf, .wmx, .wmv,
.wm, .wmp, .mpg, .mpe, .mpeg, .dat, .ifo,
.vob, .m1v, .m2v, .tp, .trp, .mts, .m2ts, .m2t,
.dmb, .mp4, .m4v, .k3g, .3gp, .skm, .dmskm,
.imp4, .rm, .rmvb, .mkv etc, etc.
HP Computers &... | Answered on Dec 19, 2019
Hi Llewellyn,
Did you delete the program from your programs folder or did you uninstall it through 'add/remove programs' in your control panel. Simply deleting it from your list of program files will not uninstall the program.
Deleting installed programs could also corrupt your windows installation.
Best wishes,
Graemevm
HP Computers &... | Answered on Dec 18, 2019
you need to ask HP, that, it's laptop right?
is this and HP ENVY notebook????
Pavilion notebook?
we need the PCs service tag product number,
15 means nothing, ever.
the number may end in #ABA! mine all do.
tell that and HP can help.
The newer the PC the more hard this becomes
BY DESIGN !!!
hp 15 is not the full model name:
example #1, the service tag is read first, then told what it is. (wild example #1)
HP 15-bs031wm then go here and ask HP, what to do. notebooks
https://h30434.www3.hp.com/t5/Notebooks/ct-p/Notebook
BIOS PW lost. (next time do not use this unless work for CIA/DOD ,etc)
HP has fix, call them, online lots of $scalpers, sell it.
The year the HP laptop was made also changes the answer.
Here are the historical evolution of HP PW.:!
1: long ago jumpers on the motherboard.(kids stuff)
2: then coded, eeprom PW chip used, and backdoor PW that HP tells you after you enter PW blank 3 times.
you see code only you have and HP tells the new PW.
3: then TPM chips and UEFI, the new age. (hard nut )
only HP can cure those PERIOD. Not scalpers..
4: also what you turned on in bios can also make this worse. like fingerprint logins, etc...
I own and HP8540w that can get in 3 ways. 2010 made.
BIOS PW
finger print swipe
and the magic intel way me answering 3 questions.
what you have NOBODY KNOWS what you turned on...
that be first after posting your service tag.
that tag.
here ill beg for your tag... sad no?
HP moved the service tags many times
easy see on bottom then on laptops, in the battery well battery out. and last no tags at all , only seen in BIOS screen 1. (now locked out ouch)
see hp 17 here, the letters after the number matter.
the product number matters most. !!!!
https://www.pcdied.com/TAG-jive/hp-17-ours1W.jpg
HP Computers &... | Answered on Dec 17, 2019
Shut down the notebook, unplug the AC Adapter and then remove the battery. Hold down the Power button for a full minute. Plug in the AC Adapter ( leave the battery out for the moment ) and see if the notebook will start.
HP Computers &... | Answered on Dec 16, 2019
HP 2x1x16 Kvm Ip Switch 16 Port 410530-001 408965-001 Logo
0 questions posted
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
all new forum in desperate need some
  • Computers & Internet
