20 Most Recent
SMC EZ Switch SMCFS8 8-Port Questions & Answers
How to reset a SMCFS8
http://www.smc.com/index.cfm?event=downloads.doSearchCriteria&localeCode=EN_USA&productCategory=6&modelNumber=1482&partNumber=0&downloadType=8&knowsPartNumber=false
Gave me the manual. The product you listed is an unmanaged switch not a router. Thus, it doesn't have an web interface. You can try unplugging the device for a while and then retrying to connect to your firewall/router/local network. Also check if your computer will connect to the network without the switch. If you can connect directly without the switch, check if your product is still under warranty.
MBP8,1 late 2011 new battery not working
You realize people reading this have no idea what this mumbo-jumbo means. Brett has no idea and he is the master of all masters in lateral thinking!
'make model (what it is)', plus a detailed description of the issue!
Wat is the smc networks use for
SMC Networks serves up networking equipment, with or without wires. The company makes wireless local area network (LAN) devices designed for use in homes and businesses.
How to solve USB device not recognized ?
different USB port. There are usually 3 or 4 of them. If you can, format the USB drive (if you have nothing on it or already have copies of what is on it). It will take 10 seconds, but will wipe all data. It should be recognized then.
When trying to use the
look for a windows xp driver file on the included program compact disc that may need to be installed before you use the included program.
