20 Most Recent Samsung Yepp YP-T7JX MP3 Player Questions & Answers
If you want to download free music. You can reach this aim by download music from Youtube, Last.fm, etc. Follow below steps, to know the detailed information. Leawo Music Recorder is a super recording software to help you record various kinds of music from multiple sources like online music like YouTube, computer audio, and built-in input audio. The recorded music files will be saved into an output format of MP3 or WAV.
1. Run Music Recorder on your computer and enter the recording interface. Audio source should set firstly before music recording. In order to record the music from YouTube, we should choose the option "Record Computer Audio".
2. Click the red button "Start" to make Leawo Music Recorder begin to work. Then play the music on YouTube. You should note that the music recorder should work prior to playing YouTube music.
If you want to decide the start and duration time of the recorded music, just click the icon button "Task Scheduler" then you can finish this customized setting as per your requirement.
After the music has been recorded from YouTube, you can use Leawo iTransfer to move the recorded music from computer to your iPod
Leawo iTransfer is a professional transfer program for transferring files between iOS devices, iTunes and computer. Various kinds of files are supported by this software such as music, apps and photos, etc.
1. Run Leawo iTranfer after you have downloaded the music on your computer. Connect your iPod with your computer via USB cable. The library of your iPod will be detected automatically and shown in the left sidebar of the window.
2. Import files to the software from computer in the following four-way:
I. Drag and drop the music files into iTransfer directly.
II. Click the button "Add" on the upper part which is beside the left sidebar.
III. Click the button File > Add > Add File/Add Folder on the top right corner of the window.
IV. Right click on the library and select Add File or Add Folder.
3. A pop-up dialog will be shown once you finish adding files and press the "Transfer" button. The name and the quantity of the transferred files will be demonstrated to let you know the transferring percentage. Remember not to disconnect your Apple device to your computer until the transferring is completed.
music-recorder-recording-t-ptaos1411zhprwnu0jdtasew-5-0_2.jpg For more details, check: How to Download Music from Your Computer to iPod
Samsung Yepp... | Answered on Nov 29, 2019
If your computer is windows xp Go into your control panel, press system, then hardware, then device manager. Your mp3 player is the item that should have a yellow ! next to it. Click it then up the top of the box there is a computer with a cross through it. Click that then press yes and let it uninstall, then unplug your mp3 player then plug it back in, re-install it and voila!
Samsung Yepp... | Answered on Sep 24, 2018
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Samsung Yepp... | Answered on Dec 02, 2012
use a usb line to transfer your music from your computer.
Samsung Yepp... | Answered on May 09, 2012
on the bottom of the mp3 player there is a very little button that u need a needle to push its the reset button sometimes these mp3 freeze and u must push the reset button it u dont loose any music or saved files anything like that it just basically turns the mp3 player off for u so that u can then turn it on using the play and pause button on the side of the mp3 player if this doesnt work the i guess tuff nooges
Samsung Yepp... | Answered on Oct 21, 2011
Need to have service pack 2, media player 10 only from the factory cd, take a pin and press the reset button for 5 seconds. And the charch the device not from the usb port but from a motorola cell phone adaptor. It has the same plug.
Samsung Yepp... | Answered on Sep 19, 2011
Have you tried deleting this 4MB ? ... try it.. if it didn't work.. then hard-reset your MP3 Player, because there is an error in your DB structure caused by false-copying or power spike... something like that.
HEY tracy. THIS IS MARIO FROM CYPRUS. I HAVE THE CD THAT CAME WITH THE DEVICE. THE USB DRIVER FOR THE MTP AND THE DRIVER FOR YP-TJX XP MODE ARE ALL IN THERE. I WILL UPLOADED IT SOON <2 DAYS> AND I WILL TELL YOU WHERE TO DOWNLOAD IT FROM. I SEEK AND TIRED BECAUSE WHEN I LOST MY FACTORY CD ALL I COULD FOUND WAS SOMETHING ABOUT FIRMWARE, FLASH E.T.C. WAIT AND SOON IN ENOUGH WILL BE YOURS!!!
Samsung Yepp... | Answered on May 25, 2011
Please charge the player if it is not turning ON. Let me know if you require any further assistance.
Samsung Yepp... | Answered on Mar 12, 2011
Please make sure to charge the player if not charging. Please let me know if you require any further information.
Samsung Yepp YP-T7JX MP3 Player Logo
103 questions posted
Top Samsung Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
YP Samsung
  • YP Samsung
Most Popular Question
samsung digital audio player yh 925
  • Audio Players & Recorders
