20 Most Recent
Samsung Digimax S800 Digital Camera Questions & Answers
On my Samsung Digimax S800, when I put the memory card in, it says to check sd card. What do I do about it?
When the card worked before, check if you did not switch the lock switch down. And check all contacts on the card and in the camera. They should be clean and shiny.
When you recently bought a new card you could have bough a SDHC card and these won't work in your S800.
The S800 only accepts MMC and SD cards, The SDHC and SDXC cards won't work.
A few years ago you still could buy 4 Gbyte SD cards. Now even most 1 Gbyte and 2 Gbyte cards are already SDHC. SDHC was introduced at least 7 or 8 years ago, so all new devices accept SDHC. The SDXC was introduced at least 4 years ago, so in a couple of years, you perhaps only can buy these cards?
Samsung Digimax...
Answered
on Feb 21, 2015
Www samsungcamera com
Some cameras have a maximum limit to the capacity of memory card that can be used. Please make sure that you have the right capacity card. There is also a lock (yellow tab on the side) on SD card. Make sure that it is not in the 'lock' position.
Samsung Digimax...
Answered
on Aug 25, 2014
Cd-rom not compatible with windows 7
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Windows Photo Gallery or
Picasa.
Samsung Digimax...
Answered
on Feb 17, 2013
My camera won't connect to my laptop. I try
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
Samsung Digimax...
Answered
on Feb 11, 2013
How can i download diriver
You don't need a driver.
Picasa.
Samsung Digimax...
Answered
on Feb 11, 2013
Can I download software on to p c as I have
Picasa.
Samsung Digimax...
Answered
on Feb 11, 2013
