20 Most Recent Samsung PPM42M5 42 in. HD-Ready Plasma Television Questions & Answers
Horizontal lines = bad sustain buffer boards = replace buffer boards
Vertical lines = bad plasma panel = get used or get new
My request = don't kill the messenger :-)
Samsung PPM42M5... | Answered on Oct 09, 2012
try to check the sound board or play a DVD to your TV to test if the TV has a problem.
Samsung PPM42M5... | Answered on Jun 19, 2012
hi, dig in the menu to choose the audio output, from internal speakers to external ones
hope 2 help
http://www.bostonrecycling.net/
If you are using a scart lead it might not be pushed it right and this will only give you picture. Push it in bat both ends and it should work. If hdmi cable try different slot I have LCD TV and 1 slot stopped working on it. Hope ya get it working.
Samsung PPM42M5... | Answered on May 28, 2012
Usually cheaper to buy another board as individual parts are not sold--be aware the burning may be a issue elsewhere--you may replace the board and have it instantly burn up also---the Y board goes directly to the panel and it could be the real problem---fatal if it is.
Samsung PPM42M5... | Answered on Apr 01, 2012
Try removing and re-seating the ribbon cables, sometimes they don't make proper contact, just grip the ribbon top.
If not, take it to a service engineer. The 'let's see if replacing this fixes it' idea is a very expensive way to repair televisions. Many replacement boards that you buy are from stripped machines and may be faulty when you get them. Only dealers can return them. You need to be able to diagnose at component level. The course is 2 years full time education
Samsung... | Answered 2 days ago
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Samsung... | Answered 3 days ago
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
1. Press the TV button to set the remote to TV mode.
2. Press the POWER button to turn on the TV.
3. While holding down the POWER button, enter the code corresponding to your brand of TV. •If there is more than one code listed for your TV in the table, enter one at a time to determine which code works. Example : For a Samsung TV While holding down the POWER button, use the number buttons to enter 00, 15, 16, 17 or 40.
4. If the TV turns off, the setting is complete.
•You can use the TV POWER, VOLUME, CHANNEL, and Numeric buttons (0~9)
Go to page 14 of the user manual
https://fccid.io/A3LHTZ320/User-Manual/Users-Manual-1-1061180
If none of the bluray movies playing then your BD optical has failed. Get a technician to check the unit phisically.
Samsung... | Answered on Nov 14, 2019
hi Chrestell! how are you? thanks for using fixya!
I just want to ask you if you could tell me the complete Samsung Models, it is just not clear to me.
Thank you.
Samsung PPM42M5 42 in. HD-Ready Plasma Television Logo
Popular Tags
12 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
  • Samsung Televison & Video
Most Popular Question
vertical horizontal lines from any item
  • Televison & Video
