20 Most Recent Samsung LN-S4041D 40 in. LCD HDTV Questions & Answers
You will still need to use your SAMSUNG remote to switch the source inputs since I do not beleive the DIRECT-TV remote has full function of the SAMSUNG remote.
Samsung... | Answered on Nov 19, 2019
Tv have a power supply board problems.That the board where the tv power a/c cord plug into it.Take the tv aparts and check the tv power supply board carefully for dying and leaking components parts that are calling capacitors parts these capacitors parts are most likely bugles ups or puffing up onto it tops and leaking.These capacitors parts are dying and leaking that why it give the tv power supply board low power and long time to power up the tv.Have all the tools and know basic electronic also can do basic soldering work?Yes,than changes all these dying and leakages bulges ups capacitors components parts with the same Miro Fared and thoes voltages on the capaictors parts like 5 or 10 volts higher than those capacitors parts was in the power supply board u are replacing,these 5 or 10 volts higher rating will help these newly replace capacitors parts withstand heat better and last longer and the operation on the tv power supply board.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power suply board for the replacement.
Samsung... | Answered on Oct 30, 2018
there is a defect in your tv.there is parts on it shorted consult your samsung service center to fix your problem
Samsung... | Answered on Jul 17, 2018
It's the power board. eBay has them.
Samsung... | Answered on Sep 23, 2017
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Samsung... | Answered on May 08, 2017
The problem is 4 capacitors on the power supply board. Just had mine done under warranty. They (Sears) replaced the whole power board but you can get larger capacitors and just replace those for alot cheaper if not under warranty.
Samsung... | Answered on Sep 03, 2015
it is a power supply issue. options 1- replace the power supply
2- this unit has an issue with 4 capsitors on the power supply which sit side by side and are about 10 volt each replace them with standard 16v caps.
Samsung... | Answered on May 25, 2015
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Samsung... | Answered on Dec 19, 2014
Moat likely it is because your power supply is defective and it is not producing tv sufficient voltage to power the backlight. I would replace the power supply.
Samsung... | Answered on Jun 30, 2014
Sounds like either the buttons on the side of the tv or the function board is not working.
Samsung... | Answered on Apr 17, 2014
To all who are having power supply issues: Samsung is now acknowledging a problem with the faulty capacitors. I called 1 800 726-7864 and they said they would repair certain out-of-warranty TVs if the problem is related to the capacitors. I just called and they are sending a service rep out to diagnose the problem
Samsung... | Answered on Mar 04, 2014
Clicking noise and tv does not start. Most of the times it is the power supply board which is found defective. But I have found Main board also responsible for this problem. Please consult some qualified technician.
Samsung... | Answered on Dec 29, 2013
Mother board burnt means you have to replace it. But before you must see that the other board are ok.
Hi Metthew,
Most probably the TCON board in your tv is defective. Please consult some qualified service technician. Most of the time the company service centers ask you to replace the entire LCD panel, which is an expensive affair. TCON board is a small part of the panel. and its job is to distribute the picture information across the LCD screen. Good luck.
Samsung LN-S4041D 40 in. LCD HDTV Logo
196 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
LN Samsung
  • LN Samsung
Most Popular Question
screen go black but yet still sound
  • Televison & Video
