20 Most Recent
Samsung HP-R4262 42 in. Plasma Television Questions & Answers
Popping sound then no power
Hi! I think something to do with power supply.Try using different power outlet or have to replace the fuse inside the unit.If your tv is withing the warrenty dont open it,call samsung
Not start
Denotes short circuit at the main board. Contact any service technician, or authorized service centre for Samsung. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" will make surf easy.
Ps 42q96hd
The digital part? Do you mean you have sound but no picture/video? Does the power LED on the front of the TV flash? Just about every board in the TV can cause this symptom. You may need a trained TV technician diagnose it further. If you need replacement boards,
Tri-State Module is a good vendor for me.
Hi my Samsung 42" SP42Q96HD
this problem is complicated because it involves the ability to diagnose a plasma tv because there are to many possibility'sto this problem . to make it simple there's a short circuit in your tv obligating it to turn on and off now the defective board is dead making a no turn on .
Black line about 5" wide
one of your buttom scanning bords is dead or it needs to be cleaned or simply reconnected properly , at the buttom of your plasma tv you have 2 to 4 small boards with flex connecters one of these flexible connecters will be adjacent to the black line ,replace entire board because it cannot be repaired
