20 Most Recent Samsung LE32R41BD 32 in. HD-Ready LCD Television Questions & Answers
2answers
Samsung LCD flat screen goes black. Turn tv off
Sounds like your power board is failing. contact samsung tech support and describe your problem. some parts on samsung have lifetime warranties and the service call is free.
9/6/2019 2:17:37 AM • Samsung... • Answered on Sep 06, 2019
2answers
Remote not working!
Hi, I have just had same problem and rang Samsung who sorted it ! All that was required was to reset remote by taking out the batteries then press power for approx 10 seconds and then replace the batteries and hey presto it worked!
8/7/2018 2:02:11 PM • Samsung... • Answered on Aug 07, 2018
12answers
Digital Tv is stuck on a channel
I have found the solution at last :)
Put the TV in standby and press these buttons in order
Info, Menu, Mute and Power on.
You will then see a hidden menu, on line 12 select reset
Bingo :)
7/11/2018 8:09:50 AM • Samsung... • Answered on Jul 11, 2018
0answers
Samsung LE32R7 3BD LCD will
Sounds like the T-Con board is going bad; You can get replacements here : TV Parts Universal TV Stands DLP Chips ShopJimmy
2/14/2018 9:53:30 PM • Samsung... • Answered on Feb 14, 2018
SAMSUNG LE32R41BD We were watching tthe TV and
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
7/18/2017 1:39:05 PM • Samsung... • Answered on Jul 18, 2017
2answers
No signal onthe screen
If you are connected to a high definition cable box or satellite tv box you would not need to turn to channel 3 on your television. The television would need to be in the right input either component or hdmi. If someone connected the tv to the cable box or satellite tv box with a coax cable like an antenna cable then the tv channels will be available on channel 3 as well but they will not display in high definition. You change channels with the cable box/satellite tv box remote control. If the above is not correct and you are only connected to an antenna cable and not to a cable box or satellite tv box you will need to complete a channel search from the tv menu. It sounds like you are using a cable box/satellite tv box and that the tv is on the wrong input. If the cable box/satellite tv box is not working (i.e. just a black screen) on your television than that is a different matter entirely.
12/3/2016 2:13:29 AM • Samsung... • Answered on Dec 03, 2016
When I switch to hdmi and back to tv I have to retune all the tv channells
Main system control IC fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
1/24/2016 12:16:35 PM • Samsung... • Answered on Jan 24, 2016
How to get Netflix on this TV
You can't.
9/28/2015 1:05:05 PM • Samsung... • Answered on Sep 28, 2015
Why is there no sound on my TV? Picture good
Hi David, Failed speakers is a common cause for no sound in lcd/led TVs. Please check.
4/29/2015 12:37:06 AM • Samsung... • Answered on Apr 29, 2015
Samsung 32 hdtv has sound but no picher
11/4/2014 1:56:36 PM • Samsung... • Answered on Nov 04, 2014
When I hit the info button, the program listing does not show. How do I set this up?
Info doesn't bring up the program listing. It just tells you about the current programme. You'd know this if you read the manual. If you watch a list of the TV programmes, then you need to press the buttons listed on page 57 of the manual. LE32R41BD LE32R41BDX XEU Support SAMSUNG UK
9/15/2014 8:50:51 AM • Samsung... • Answered on Sep 15, 2014
Can you use both HDMI 1 and HDMI 2 input for TV and Blu-Ray player?
tv problem should show both
8/16/2014 6:09:46 PM • Samsung... • Answered on Aug 16, 2014
0answers
Samsung LE32R41BD 32 in. HD-Ready LCD Television Logo
246 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
LE Samsung
  • LE Samsung
Most Popular Question
samsung lcd flat screen goes black turn
  • Televison & Video
