20 Most Recent
Samsung AH5900092W Remote Control Questions & Answers
Please tell me the samsung cs29k40mh TV' code for
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "
brand name" to your device; to which you want set-up codes; in the "
Search box at the top right of the display window" to get gathered related posts
9/6/2017 1:49:24 PM •
Samsung...
Answered
on Sep 06, 2017
My problem is with my
Set your device with an other set up code and then check. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Programming Notes
3/4/2017 12:09:43 PM •
Samsung...
Answered
on Mar 04, 2017
Remote control error
We need more information to assist you. Remote control error on your computer? Remote control error on your DirecTV remote? Is it remote control for RDP connection?
Best of luck cheers
9/6/2016 7:51:03 PM •
Samsung...
Answered
on Sep 06, 2016
Changing Samsung Remote Codes (2 TV's Same Remote Frequency)
There is NO solution to this problem. I'm an electronics engineer. I have three Samsung TV and IR remote extenders. It is a continual problem. If someone told you could "re-program" the Samsung remote, they must have thought you could write assembly level programming code.
There is NO incentive for Samsung to modify their highly popular, simple, cheap remote system.
Believe me, I even tried putting polarizing filters over the IR sensors but the ones for cameras do not polarize light at IR frequencies.
9/3/2015 6:29:15 PM •
Samsung...
Answered
on Sep 03, 2015
Configuring Sky remote
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
5/17/2013 3:28:54 PM •
Samsung...
Answered
on May 17, 2013
I have a samsung lcd
We would be happy to help get that fixed. It sounds like you may be in the incorrect screen format. Press the * located below the number 7 on the DISH Network remote control. Cycle the formats to determine the screen format that fits best.
We hope that this fixes it for you. Thanks so much for choosing DISH Network!
Phillip Chang
DISH Network Customer Service Department
3/2/2011 7:12:10 PM •
Samsung...
Answered
on Mar 02, 2011
I need to program my dish network remote to my
Hello! Dan Busa here with DISH Network try this link.
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Daniel Busa
1/16/2011 2:25:56 AM •
Samsung...
Answered
on Jan 16, 2011
I need remote control code for a Samsung LTP2035
Ok I can help you with this for sure but need to know what kind of remote you are trying to program the code into? Remotes use different code sets based on the remote type.
Please just reply to my answer here with the type of remote you have and I will get right back to you with the codes.
Thanks,
Tim
11/3/2010 10:29:54 PM •
Samsung...
Answered
on Nov 03, 2010
