20 Most Recent
Samsung TV Remote Control Questions & Answers
How to program a samsung remote/AK59-00149A
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
How do I program my Samsung aa59-00784c remote
On TV remote press Mode button or TV button. Then select HDMI 1 or HDMI 2 depending on where the cable is inserted in the TV. Now press the SET button & enter the code. Try the following codes:
0019 0618 0644 0056 0060 0587 0037 0178 0030 0556 0009 0702
0774 0093 0217 0448 0747 0482 0370 0264 0329 0090 0032 0216
0290 0154 0150 0092 0072 0179 0208 0519 0156 0163 0625 0226
0812 0817 0821 1060..
If the above codes don't work contact TV manufacturer for the code.
How do I get the codes for a Samsung remote
what model is your remote if you let me know the model and the make of the unit you want it to work i can give you the codes or tell you how to manualy search for you unit but i need to kno what controll you have as they all differ but if you go onto the samsung web site you should be able to do this yourself hope this is some help
Cox Cable Communications remote (URC 7820b01-09541) with Samsung
The Cox URC-7820B is not the one shown in the picture.Guess that's the Samsung LCD TV.
Here is the Manual for the 7820B, which is the Learning version of the 7820. Learning means if the TV codes for Samsung in the Manual do not work, then you can Learn them from the Samsung Remote by pointing their IR light(LEDs) at each other and follow the Learn the instructions in Manual:
www.urcsupport.com/images/uploaded_images/Cox_M7820.pdf
Need control code, to operate dvd samsung
Yes. I found the code. To operate Samsung HT-Z 310 with a remote control of Samsung TV, You have to turn off DvD, and then select Dvd on the remote(press the dvd button), press SET on YOU
remote control, input the CODE(020). For different Samsung dvd. you can try.codes from 000-to 080. The DVD button must blep three times. After that swich on Dvd. Enjoy....
