20 Most Recent
Samsung HL-R5678W 56" Television Questions & Answers
Replacing light tunnel (instructions)
Hi, if you did not get help until now, i can send you step by step instructions and photos how to do it. I did several of these and it is not a big deal.But you will have to take apart a very sensitive optical device and if you are not confident that you can do it do not start this.bp67-00291a is the part number for the light tunnel.post a message here if you need that file with instructions
7/27/2015 5:11:25 PM •
Samsung...
Answered
on Jul 27, 2015
Just replaced color wheel. When
I had a similar issue with mine from the factory. There was a grey/black shadow in the upper left. Called for repair. The guy took off the circular access panel on the left back side and there was a fingerprint on the projection lense. He cleaned it and it disappeared. Sounds the same. Maybe touched the lense replacing the color wheel?
8/20/2011 8:19:17 PM •
Samsung...
Answered
on Aug 20, 2011
On my HL-R5678W, I have several horizontal lines
Hi,It sounds like your DMD chip is going bad.This is how the dmd works: http://electronics.howstuffworks.com/dlp1.htm Basically the dmd is composed of 2 million pixels that create the image ,when you start getting symbols or pixilation that will be the dmd chip that is going bad.Good luck and God bless you!
11/3/2009 7:18:45 PM •
Samsung...
Answered
on Nov 03, 2009
HLS5087 DLP - Samsung
You probably have a bad Light Tunnel. Samsung has a Tech bulliten and recall for this defect and might pay for the repair. Call 1-800-SAMSUNG and ask for the ECR Group and explain the symptom. If they resists to pay for repair mention the recall.
7/16/2009 2:17:27 AM •
Samsung...
Answered
on Jul 16, 2009
