20 Most Recent
Samsung TXR3079 TV Questions & Answers
Samsung turns off and on
This will most likely be a hard problem to find. These sets usually run what is called a 'switched mode' power supply. The power supply is starting, detecting a fault, (ie a heavy current drain), and then turning itself off to protect itself. Then it starts again, detects fault, shuts down, etc, etc. First place to look is around the horizontal output section as this is where the high voltage, high wear and tear, high temperature components are located and fail. I doubt that it will be as simple as a bad soldered joint but it costs nothing to look. Make sure the set has been turned off for 30 minutes or more before you touch. Capacitors take time to discharge. Please don't take offense, but, if you do not have experience in this field then I would consult a technician,
Lcd dark spots
Its an internal hardware problem, specifically the LCD panel is defective. No fix for that, replacement is the only option
All service codes of china made ckts
Do you think it is so easy to type in all here? Not possible.
If you wish to get more details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/ Time slide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.
Service mode entry, adjust and exit procedure to many brand TVs are given in details.
Txr3079wh
The fault should be to its EHT section circuit. This includes Line Output Transformer [LOT for short], and horizontal output transistor. See the pictures of suspected components.
Seeing a dark shadow on
According to your observation in the black flickering lines this fault is from your t-con board there may be a loosed solder or cold solder from the t-con or to the logic board. This kind of trouble is fixable but it should be done in actual testing of the unit to be sure where the fault is. I suggest that you should contact a technician to do it for you and save you from stress. Good day and best regards.
It has colur patches
Sometimes, rubbing the patch with a soft cloth, pushing firmly, can help this problem.
To unclok child lock tv samsung
Press Menu,press the up-down button to select set-up,press Enter button,press the up-down button to select v-chip,then press the enter button,press the number of buttons to enter your 4-digit pin,the v-chip menu is displayed, press the up-down button to select Parental Guidelines,then press the enter button, press the up-down button to what you want to do, press the exit button to exit. hope this helps..
Need code to program to my samsung tv for my one
033,034,035,036,041,086,093,094,097,100,103,111,115,149,215...hope this helps..
Dead Samsung txr 3079 HDTV
Check the small glass fuse on the power supply. I found a close match at Radio Shack for $4.00.
Good luck
