20 Most Recent
Samsung SyncMaster 940BF (Black) 19" LCD Monitor Questions & Answers
Broken mount on back of monitor to base
the easiest solution would be to epoxy the mount back though you may loose ability to tilt monitor, be sure not block any air holes. when setting together tape it to proper spot and let set for recommended time on epoxy(get at hardware store).
11/11/2019 5:46:49 AM •
Samsung...
Answered
on Nov 11, 2019
Samsung 940bf-screen stays black
Your monitor is having a problem with the power supply.
Because of the small spaces in the monitor case heat builds up and
causes parts called capacitors to blow. If you can solder you should be
able to do the repair yourself. Go to our
web page at:
www.ccl-la.com/badcaps.htm
and look at the pictures and repair guides. Open your monitor and look
for parts that look like the pictures. Replace any that you see and
your monitor should be back operational.Be sure to install the new
parts with the polarity stripe on the side
going the same direction as the bad ones came out. You will need to
replace them with a high quality part with high temp value (105c). If
you don't want to do the repair yourself we do offer a repair service.
I hope this helps, if so please rate my solution.
Buddy
Corporate
Computer
www.ccl-la.com
12/19/2014 5:37:18 AM •
Samsung...
Answered
on Dec 19, 2014
After replacing screen there is a grayish look
you replaced the inside LCD screen?i guess there is a full story here, but...?????light hours,?you mean with windows open and the screen goes gray?some monitors and tv's do that, now. called GREEN MODE.turn it off. My stupid TV (LG) goes gray with a reading lamp on.silly to the extreme that. Im sure yours is not with a room light sensor, but do RTM.as you know , the screen is black lighted.and old screens (2005 it is) do get gray and other effects.my old view sonic, (now on server duty, off mostly)has dim and yellow back lamps.and the LCD has age effects.this is all 100% normal for 8 years, full time service,in fact lucky it works at all. truth being.elaborate what you see better may be we can hone in on the reasons. and the what you touched inside.
10/24/2013 7:42:22 PM •
Samsung...
Answered
on Oct 24, 2013
How to fix pink colur screen on sync master 794 mg samsung
The connecting cable or the video card would be the first suspects. Try a different cable to connect the monitor first, if there is no change, the video card in the computer would be second to look at. Can simply connect a different monitor to your computer to troubleshoot this. If the testing monitor works, it will be the graphics card that is the issue.
6/19/2022 1:41:48 PM •
Samsung...
Answered
on Jun 19, 2022
Vga connection to the mother board
If your motherboard doesn't have a VGA connection, then that means it most likely does not have an integrated video card. If this is the case, then you will have to purchase and install a video card. It is very easy and your local Best Buy should be a great resource. The geeks there are usually very enthusiastic about explaining how to do it. I use to order from newegg.com, but they have become very commercialized and overpriced, like Best Buy. You can check tigerdirect.com or my favorite Amazon.com. Best Buy will price match any items they sell, including those on Amazon. If you need further help, I’m available over the phone at
https://www.6ya.com/expert/jason_3e83613ef5f2a68b
3/13/2015 12:06:38 PM •
Samsung...
Answered
on Mar 13, 2015
Samsung syncmaster 223bw At first when the monitor
Most new LCD tv and monitors color,brightness,vert.hold, horz.hold,resolution, ect., are all controlled by a single programmed EEPROM, that costs more to replace than a new monitor/tv. You pay for the programming, not the chip.
12/1/2014 3:37:18 PM •
Samsung...
Answered
on Dec 01, 2014
