20 Most Recent
Samsung SyncMaster 930BF 19" LCD Monitor Questions & Answers
No image
Sounds like the monitor power supply may be faulty or noisy - most probable cause is that it needs the capacitors changing. If it has an external supply try changing it as that is a cheap fix worth a gamble - if power is internal then change the monitor.
7/23/2017 3:17:08 PM •
Samsung...
Answered
on Jul 23, 2017
Screen is blank. Monitor makes rattling noise.
Hi There, It sounds like your monitor is faulty.
Connect your monitor to a laptop, and try to see if you get picture that way.
Go to Graphic Properties and select Clone screen.
you should see the same projection on the laptop screen as the monitor.
Let me know the results.
5/30/2014 2:27:47 PM •
Samsung...
Answered
on May 30, 2014
Parts board
Try second hand shop. Unless you want to sell it, no point to get one.
10/30/2013 5:13:38 AM •
Samsung...
Answered
on Oct 30, 2013
My new monitor will not display RED. All the
Check for a bent pin in the VGA connector. Each color, Red, Green, and Blue has its own pin for the signal. If its pin is bent then no color!
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
1/3/2010 2:42:57 PM •
Samsung...
Answered
on Jan 03, 2010
Syncmaster 930bf black screen
its a common problem for LCD monitors after 2-3 years of use. The power supply that powers the back lights has gone out. If you can solder you should be able to do the repair yourself. The problem is caused by parts called capacitors that get over heated in the monitor case and blow out. You can go to our site at:
www.ccl-la.com/badcaps.htm to see what the parts look like when they blow out. Open the back of your monitor and replace all of the ones that look like the pictures. We have repair guide on the site for your model with pictures of what to do. We also have a repair kit available. If you don't want to do the repair yourself we offer a repair service for $30.00 plus return shipping. Let me know if you have any additional questions.
Buddy
Corporate Computer
www.ccl-la.com
9/15/2009 7:56:10 PM •
Samsung...
Answered
on Sep 15, 2009
Blinking power LED
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will
blow a power supply. The problem is caused by parts called capacitors
overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site
www.ccl-la.com/badcaps.htm You
can take the back cover off your monitor and look for the bad
parts,replace any that look like the pictures and your monitor should
work fine. The capacitors do need to be installed with the correct + and
-connections, note the stripe on the old one and insert the new one
the same way. If you don't want to try the repair yourself we offer a repair
service for $35 plus shipping. If your problem is not the capacitors
then it would be the backlights and that is much more difficult to
replace.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
7/9/2009 2:48:36 AM •
Samsung...
Answered
on Jul 09, 2009
Samsung 930BF Problem
try the monitor on a friends computer or family menbers computer first as it may be your grafic card at fault.
6/1/2009 11:53:20 AM •
Samsung...
Answered
on Jun 01, 2009
