20 Most Recent
Samsung SMT-190 19" Flat Panel TFT LCD Security Monitor Questions & Answers
The monitor is currently black, power is on, I
Hello.It can be one of two things:1. A power issue2. A firmware issue1. In the first case the one thing you can do is to power off the device, unplug it, wait about 5 minutes and then press and hold the power button for 20 seconds with the cord unplugged. This way you will deplete the capacitors in the power section of the device. If that doesn't work it's most likely the internal power transformer or one of the capacitors is toasted. In this case you must go to pt. 2.2. In the second case you can't personally do anything because you must address the issue to a certified Samsung service provider in order to examine the issue and perform the firmware rewrite or the intervention needed to repair the device.Hope this helps, keep me update please,Vlad Mototolea
How to unlock a phone
Have you forgotten your mobile password? Try default security code for your mobile. It doesn't work simply reset your mobile.
You can easily reset your mobile by using master reset code. If you need master reset code you can visit this site Unlock-free.com
here you can get the code and reset your mobile easily.
Unlock-Free.com
System Initializing
Have you tried unplugging the monitor from the 120 volt supply for a minute or two then replug and turn on. Like computers and some flat panel TVs they can freeze-up after an unplanned power loss and need rebooting
I have a Samsung SMT-190 19
More then likey yuor Inverior Board is going bad if not that, Its the Power Board
First check Invertor This Happens a lot Its hard to find someone to fix it.
Well I had a hard time. I just waited and bought one for parts and fixed it Myself
Good luck
PS. You can still use it just get a different Monitor. The Video out on the Samsung to the
Video in on a different Monitor IT WILL WORK
How to master reset
Master Reset or Factory Reset
When Factory Reset is performed, the setup value will factory default setting
When initialization starts.
1.Select System Setup from Menu Screen.
2.From the System setup submenu, Set Factory Reset to ON
3.When you exit Menu, The phrase FACTORY RESET Appears on the monitor and
The Initialization starts.{ON/OFF} Use arrows UP-- DOWN & , kEY TO MAKE CHANGES
HOPE THIS HELPS
I turn it on and it eneates, and starts to come and then goes off?
Sounds like what we had once with our Samsung TV.40"(The TV clicked a lot and more and more often before it came on)The service man soldered in a part into the internal power supply.So you have to bring it in, I guess.Another idea: the cable is not plugged in right and came loose, so check that, on both ends.
