20 Most Recent Maytag MTB2456G Top Freezer Refrigerator Questions & Answers
Hello, Thank You for using FixYa. I will be helping you today.There are 3 screws holding the icemaker to the wall remove them unplug the icemaker and run hot water through it let dry and reinstall.
Thank You and please rate my answer if it was helpful..
Maytag MTB2456G... | Answered on Jun 11, 2011
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Maytag MTB2456G... | Answered on May 11, 2011
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Maytag MTB2456G... | Answered on May 01, 2011
On vacation I would probably shut off the water valve and disconnect the wiring harness to the ice maker.
Maytag MTB2456G... | Answered on Apr 05, 2011
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Maytag MTB2456G... | Answered on Sep 12, 2010
Been there, done that. You need to have a new computer board installed in the fridge near the top. Ours got hit by static lightning ang blew two of them in two years. When they go out, the defrost cycle fails and Ice builds up in the freezer in the back middle. Take the back vover off in the freezer and you'll see it packed with ice since the defroster is not getting the signal to defrost. order a new computer board, install it in the top of the fridge side, in the back, above all those controls on the back right side in a white case to hold the board. defrost the ice by using a hair dryer and letting all the water drain out and get it dry. Those PC boards do not like static at all
Maytag MTB2456G... | Answered on Sep 07, 2010
Water is either coming from the water-supply to the ice-maker, or from an overflowing evaporation tray under the refrigerator. Check the tray first. If it's full, it could still be coming from the water-supply, or from the defrost cycle. If the tray is empty, it's definitely the water supply. If the tray is full, then empty the tray and turn off the water supply. Wait a day or two to see if anything changes. If the tray doesn't fill up, then it's the ice maker supply. If it still fills up, then there is something wrong in that there is so much defrosting to do. Give this a try and let us know what happens. Thanks for using fixya.
Maytag MTB2456G... | Answered on Jun 14, 2010
Your model does not have an auto damper so the most likely cause is the themostat is out of calibration or the control vent from freezer is open all the way. Try adjusting to warmer temps and see if compressor will run less. If the only action the thermostat will do is turn off then for sure the thermostat. If the compressor continues to run at warmer tempertures the thermostat wil need replaced. If the dammper vent is stuck open or broken will allow the colder heavy air to settle to bottom section. Sea Breeze
Maytag MTB2456G... | Answered on Mar 13, 2010
check your door seals and replace the thermostat controll and adjust the vent door cables
Maytag MTB2456G... | Answered on Jan 14, 2010
It may have coincidentally chosen that time to run low on refridgerant. It can be recharged but it's best done by a pro. Thanks Dana
Maytag MTB2456G... | Answered on Aug 13, 2009
Look all the way to the rear of the control console in the fresh food compartment. Look up into the opening with a mirror. There should be a styrofoam diffuser (61005543) visible. If this is missing or damaged (many people think it packing material and remove it) it needs to be replaced. It spreads the air out rather than let it go right down the back wall to the crisper area.
One other thing to check is a tiny slot at the right rear of the same control console. a metered flow of air comes out the slot to the barrel shaped cylinder with the cold control capillary wrapped around it. Sometimes the slot gets water in it and freezes over. The unit will run too long and the cold air will settle during the off cycle and freeze items at the bottom. More often than not, when the slot freezes over, other items in the fresh food compartment will freeze......not just the bottom items.
Maytag MTB2456G... | Answered on May 03, 2009
Maytag MTB2456G Top Freezer Refrigerator Logo
26 questions posted
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Refrigerators
Most Popular Question
ice maker clogged after power outage
  • Refrigerators
