20 Most Recent Samsung - Projection TV replacement lamp Projector Lamp Questions & Answers
2answers
Samsung no picture
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!) Samsung settlement warrants older TVs with faulty capacitors Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time.. Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On WATCH THESE VIDEOS FIRST. Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise My Repair of 46 Samsung LCD TV with Bad Capacitors
10/14/2021 3:13:32 AM • Samsung -... • Answered on Oct 14, 2021
How to check sony projector lamp
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel, motherboard, powersupply ... with high quality and competitive price. any questions, feel free to contact me have a nice day! Jerry Lampdeng Limited
4/2/2015 4:03:28 AM • Samsung -... • Answered on Apr 02, 2015
2answers
No picture
check the video output its either on VGA or AV mode. check your settings. get your manual for that so it can help you a lot.
11/18/2012 7:39:33 PM • Samsung -... • Answered on Nov 18, 2012
2answers
What is involved in changing bulb in my samsung
There is no lamp in a plasma TV. If you have a "blackout" display, the unit must be taken to a service center for repair. It could be as simple as a blown fuse in the power supply or as complicated as a shorted picture tube--yes, that whole display is ONE large gas-filled tube. Definitely check for warranty status on your unit. Did you buy extended warranty coverage?Have your receipt, warranty info, etc. when you take the unit in...most major suppliers can look up all the info on their computers but, if you have an extended warranty, you'll need that folder with the contract number. Hope I helped you!---Rick
10/23/2012 3:13:07 AM • Samsung -... • Answered on Oct 23, 2012
2answers
Previously I posted that my Samsung HL56A650C1FXZA
Hello
You have to check the lamp inverter also. If lamp inverter transformers' winding have some trouble [even a short between adjecent winndings inside it] got a short, lamp life wont extent to its lifetime. Thit trouble may be there when you repalce the lamp before 6 months ago. Just replace the lamp inverter board also with this new bulb. Before replacing the new bulb, check your TV thoroughly by any experienced service technician. Checking and replacing the inverter board is acually a skilled work. A damaged inverter transofrmer may even make the bulb exploded. OK.
8/25/2012 5:01:12 PM • Samsung -... • Answered on Aug 25, 2012
My 56" HL56A650C1FXZA tc went
Hi
You are right; the lamp is bad and should be replaced. The new one will cost you around $150. You can check this link to follow the step by step instructions for lamp replacement. Hope this helps...please post back for further assistance.
Daniel
7/6/2011 3:57:01 PM • Samsung -... • Answered on Jul 06, 2011
Have a 50 inch samsung
The blinking lights will be flashing a code.....
Can you please indicate the sequence of the flashing lights, as this will determine what needs to be done to fix your fault.
Cheers,
6/16/2011 10:51:01 AM • Samsung -... • Answered on Jun 16, 2011
Does a bulb go dim slowly or stop working all at
It can do both, most of the time though you will find that it just goes out completely when it goes. However there are bulbs that just start to dim, it's impossible to predict which it will do, it is random really. If you have more questions please just reply here and I will help you more. Also PLEASE rate my answer 4 thumbs up, it's extremely important to me to have 4 thumbs up... I would be forever grateful if you could do this for me. Thank you! Let me know if you have more to ask.
Tim
10/12/2010 2:13:42 PM • Samsung -... • Answered on Oct 12, 2010
My 48" Samsung Projection TV (approx 5yrs old) has
Hi...
It appears that the "light engine" has problems
It may be dust in the unit or electrical issues on 1 of the modules on the :light engine
Find a TV tech...It's the best way to handle it
8/20/2010 10:16:15 PM • Samsung -... • Answered on Aug 20, 2010
I have a Samsung HLN507w1x/xaa
yes replaced the lamp
7/23/2010 9:07:25 AM • Samsung -... • Answered on Jul 23, 2010
I have sound but sreen is bkack
i think the problem is flayback of your tv or picture tube
6/19/2010 3:32:11 AM • Samsung -... • Answered on Jun 19, 2010
Want to find out why the 42' samsung projection tv
The first thing to try is the bulb. If that does not fix it then it is time for a technician to figure it out.Other things it could be are the ballast, power supply board, color wheel or the DMD board; but I would try the lamp first.
6/9/2010 10:00:02 PM • Samsung -... • Answered on Jun 09, 2010
Light bulb not working after colorwheel replaced
Same thing happened to me (By jschmidbauer on Jan 14, 2010). How did you fix it????
5/29/2010 1:56:34 AM • Samsung -... • Answered on May 29, 2010
Random pixels stay on
Unfortunatly this is part an parcel of modern LCD technology.these pixels are permanently stuck on or off on a particular colour. The only way to fix it is to replace the entire LCD screen and hope that it doesn't get replaced with one that has more dead pixels.
Manufacturers have a tollerance to how many they will accept as ok before they replace the product. Hopefully you can live with these pixels where they are for the life of the set! annoying but normal!
1/17/2010 9:03:36 AM • Samsung -... • Answered on Jan 17, 2010
I have replaced the lamp 2 times ....think it
did you check the power supply board and also did you check the ballast our the digital board those could be the problems that you 6 year tv could have
1/7/2010 11:43:23 PM • Samsung -... • Answered on Jan 07, 2010
46 questions posted
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Office Equipment & Supplies
Most Popular Question
previously posted samsung hl56a650c1fxza
  • Office Equipment & Supplies
