20 Most Recent
Ricoh Aficio Colour 3006 Color Copier Questions & Answers
Ricoh 3006
go to service program 5-810 ( sc reset) press on, turn off the machine an the turn on again. The service code should be gone, if it come back again check for a paper jammeed or wrapping the upper
fusing roller if this is not the case replace the thermistor;
Good luck
Vittorio
Ricoh Aficio 3006 error sc452
The SC 326 is -- 2nd laser synchronization error. Meaning, the 2nd laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Basically your polygonal mirror motor unit is bad and needs to be replaced. You can replace the whole laser unit but that is expensive. When you replace the PMM unit, do so in a still air area -- as to not get anything in the unit. When you get the PMM unit -- contact me and I can walk you through the steps to replace.
The SC 452 is --- Transfer Belt Mark Detection Error. Once you fix the SC 326 error this one should be fixed also.
SC685 on Ricon AP3800C
Nothing official listed for this error code. The SC6xx are electronics related errors.
If there is a HDD, try disconnecting it.
Otherwise, you may have a bad connection to the main electronics board (BCU) or a bad BCU.
I have problem with Aficio
Verify your fusing lamp or thermofuse and replace it if necessary
If your circuit is correct, replace the power supply unit
Don't forget reset code :
Enter SP 5-810 (SC code
reset) and select "1". Then hold
down the Photo mode key and
the 7 key at the same time for
at least 3 seconds (this does
not require the main switch to
be turned off and on).
SC387 error code on Ricoh
SC387 Drum potential
error
Cause
· Uneven charge
· Worn drum
· Defective potential
sensor
Try the following
1. Clean the charge corona unit or replace the charge
corona wire and grid plate.
2. Reinstall the drum.
3. Replace the drum if necessary.
4. Replace the potential sensor.
Let me know if you need any more assistance
Error sc 452 shown on my aficio 452 color copier
sc 452 is a thermistor error code for the fusing unit of the copier. Try pressing these buttons in sequence. (yellow key) (1).(0).(7) (red Clear/stop key) and hold the red key down for 5 seconds. When the 3 or 4 boxs appear, turn your copier on and off with the main power switch. If the error code comes back then contact the seller of your copier and ask for technical service.
Ricoh CL 7000 down due to an SC-685
Do you have the copier feature option installed?
It is most likely just a loose connection on the interface between the main printer unit and scanner section. Turn off main power (red button), and re-seat the connector.
Please let me know and rate solution :)
Color bad on ricoh aficio sp c210 sf
Hi There,
print out a page from windows paint program of cyan, magenta, and yellow. see which colors are incorrect. that will help you get closer to the problem area.
the drum also may not be screwed in all the way. remove it, and try putting it back in again.
Ricoh CL 7000 error code SC 387
This Code relates to color gamma error in the Yellow development. Possible causes Low toner density in the Y toner,Toner supply Y mechanism problem( not supplying enough toner),Laser exposure problem, image transfer problem. My suggestion would be to ensure you have toner in the cartridge( but by this time it has depleted the developer), and you will need to replace the development unit and possibly the drum Unit. My best guess would be the development Unit.
Munybuny
Enlarging andf reducing on photocopiers
HI on the machine there should be a auto reduction enlarge all you need to do is press this place the original on the doc feeder and select the paper cassette in which the paper size you want the copy to be on. Once you have selected press the start button and then the reduction or enlargement is calculated for you.
Hope this helps and answers your question.
Thanks J
A3 paper
A3 size best is 1 90 to 100 grm
Sc 285 sur un photocopieur ricoh
You either have a torn ITB belt or a faulty ITB belt unit.
If this is not your problem then you could have a faulty ID sensor or a faulty PCU that is causing your Process Controll to fail and generate the SC285.
How can I fix a malfunctioning Ricoh 3410 printer?
On this page see error code 542.
Error Codes > Ricoh > SP3410DN > page 2 (printcopy.info)
- Code: 542
- Description: Fuser reload error
This SC is issued if one of following conditions occurs: The fusing temperature rises 8°C or less in 1.5 seconds; and this continues 5 times consecutively. -or- The fusing temperature has not reached 45°C within 9 seconds (after the fusing lamp comes ON while the machine is warming-up). -or- The fusing unit does not attain reload temperature within 35 s. (normal temperature) or 65 s (lower temperature - the thermistor output is less than 18°C) after the fusing temperature control starts.
