20 Most Recent RCA HD61LPW165 61" Projection HDTV Questions & Answers
2answers
Need to find color wheel dlp tv rca and color base
color wheel for model # M61WH74S
4/22/2014 9:03:32 PM • RCA HD61LPW165... • Answered on Apr 22, 2014
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
8/15/2012 5:52:03 PM • RCA HD61LPW165... • Answered on Aug 15, 2012
2answers
I have a 61
Dial the tint adjustment
12/27/2011 10:11:25 AM • RCA HD61LPW165... • Answered on Dec 27, 2011
8answers
50" RCA DLP color wheel replacement procedure
Mine started to howl last year, I sprayed out the motor using carb cleaner / lubricant. Its been running fine for over a year since.
My guess is, the bushing gets plugged with dust particals. If you catch it as soon as it starts to squeek, the carb cleaner trick may work for you too.
4/1/2011 5:24:24 PM • RCA HD61LPW165... • Answered on Apr 01, 2011
I need a color wheel part number for an rca 61"
Its a N266P.
12/28/2010 2:55:55 AM • RCA HD61LPW165... • Answered on Dec 28, 2010
High pictched squeel flashing colors
DEFECTIVE COLOR WHEEL ASSEMBLY.
12/17/2010 4:53:40 AM • RCA HD61LPW165... • Answered on Dec 17, 2010
3answers
Part #267888 just wondering if
That part is on national back order with no projected date of when it will be available. However you can get your color wheel rebuilt at the following link and they are fully guaranteed. Heres the link
http://servicemanuals.vstore.ca/
10/22/2010 10:07:06 PM • RCA HD61LPW165... • Answered on Oct 22, 2010
Need to find a color
Check this link to find the color wheel for your DLP.
9/20/2010 1:57:45 AM • RCA HD61LPW165... • Answered on Sep 20, 2010
Lost picture but sound is on
almost certain this is a lamp problem, bulbs blow up
if you remove the lamp you can see if the bulb is broken inside.
8/7/2010 11:47:49 PM • RCA HD61LPW165... • Answered on Aug 07, 2010
How do I remove the color wheel for an RCA
if you are talking about the light engine, your best bet is to have a tech do it.  if you are really talking about the color wheel, in my experience they are replaced not repaired ..
7/29/2010 12:15:28 PM • RCA HD61LPW165... • Answered on Jul 29, 2010
I have a 2005 rca
that would be the color wheel as if it was the fan it would have stopped by now. So yes check the color wheel by all means, let me know what you find, please do click the accept button for my efforts, thanks Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
4/23/2010 11:17:23 PM • RCA HD61LPW165... • Answered on Apr 23, 2010
62" RCA dlp loses color
If you hear any winding, whirling or screeching noise (Color Wheel symptoms)
If there is any vibrations in the TV (Color Wheel symptoms) you would need to change the color wheel.
4/15/2010 10:17:37 PM • RCA HD61LPW165... • Answered on Apr 15, 2010
Have a rca scenium HD61LPW165 and I get sound.
Replace Lamp Call Mats 1-800-628-1118
3/24/2010 4:42:04 PM • RCA HD61LPW165... • Answered on Mar 24, 2010
Is there a led replacement bulb for the rca
No, LED light engines are different than Mercury Vapor lamp engines. They have different power supplies and different control boards.
3/14/2010 5:13:16 PM • RCA HD61LPW165... • Answered on Mar 14, 2010
I own a RCA DLP Scenium TV 50 inch 5 years old. It
mine does the same exact thing nothing fixes it, it only goes away after the tv warms up
2/21/2010 12:18:48 AM • RCA HD61LPW165... • Answered on Feb 21, 2010
Have multiple white spots projected
You have a faulty DMD module. It has millions of microscopic mirrors that are responsible for reflecting light onto the color wheel and produce an image. A common problem on projection tvs and the only solution is to replace the DMD module. The part costs around 300$ and is a DIY repair if you have prior experience in electronics as you have to slide out the chassis to replace it hence you should know what not to touch. A service manual should be off mighty help for this repair so I will check if I have one for this model.
2/19/2010 4:08:45 AM • RCA HD61LPW165... • Answered on Feb 19, 2010
RCA HD61LPW165 61" Projection HDTV Logo
59 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
50 rca dlp color wheel replacement
  • Televison & Video
