20 Most Recent Maytag MSD2454G Side by Side Refrigerator Questions & Answers
Could be sudden compressor failure, possibly as a result of low refrigerant.
Maytag MSD2454G... | Answered on Nov 07, 2017
I have a feeling that the condenser has overheated due to lack of ventilation or overload... in which case it could be stuffed! same happened to mine and had that clay stuff melting as well... took it to an aircon mechanic and he had a look and said new parts would cost more than a new ice maker :( that suckt! lol! so bought new one....
Maytag MSD2454G... | Answered on May 04, 2017
it is most likely from the frame of the fridge that the compressor is mounted on vibrating on the floor
I use two door wedges ( available from the hardware shop and I push one under either side a bit to get clearance from the floor
the noise stopped but the problem is that there is nothing available on the market to replace the wedges
rubber buttons under the plate worked but to stop the noise they tend to make the fridge unstable when opening the door or the front of the fridge has to be adjusted up so that the door self closes
try that and if it works the you are on the right rack
if not you may have to get the compressor rubber mounts replaced as they may have collapsed and allow the compressor to hit on the plate
Maytag MSD2454G... | Answered on Oct 14, 2015
Your  deforst drain is clogged.  Every 12 hours or so your fridge does a deforst cycle.  It melts all of the ice built up on the evap coils.  There is a drain at the back of the fridge that goes to a pan by the compressor where the heat from the compressor and the condensor coils evaporates it.  Take the back panel off of the freezer compartment and plunge out that hole.  You will most likely have a build up of ice over the top of the drain.
Maytag MSD2454G... | Answered on Jan 02, 2015
Your drain is probably plugged. Remove the back panel in the freezer and keep squirting hot water down the drain hole with a turkey baster or something similar until it clears. The drain hole is located at the bottom of the coils in the freezer section. Your refrigerator goes into defrost every 8 to 10 hrs. When this happens, it melts the ice on the coils, which in turn, runs out the hole where the drain is. If something like algae is blocking or plugging the hole, it will plug up causing water to freeze over the hole. The water has nowhere to go but out the door.
Maytag MSD2454G... | Answered on Sep 08, 2014
There is a good chance the freezer drain is plugged up. You will have to remove the back panel and pour hot water in the dain area to thaw the ice and then flush the drain.
Maytag MSD2454G... | Answered on Sep 01, 2014
Is the arm that gets pushed up by the ice cubes (in order to stop making ice when it is full) in the down position? it is able to be pushed up and locked so that the icemaker doesn't make at ice and may need to be pushed down.
Maytag MSD2454G... | Answered on Aug 28, 2014
I've had the same problem and it is the thermister inside the freezer compartment. There is probably a ice build up there too. remove the 2 screws and check, you can fix this yourself and save $100 bucks.
Maytag MSD2454G... | Answered on Jul 13, 2014
not sure what is blocking your door from closing tight. there are adjustment screws on the top of the door hinges under the plastic caps that align the doors.(they are there on my maytag side by side). the water could be from some ice buildup in side the housing at the top of the inside of your fridge where the flap opens up to send cold air from the freezer to the fridge, especially if your door has not been closing properly that will ice up trying to keep the fridge cold. remove everything from your fridge, unplug it and take a blow dryer to that housing to remove any ice buildup on the flap then plug it back in. there are also diagnostic checks you can do using the temperature control buttons to test if the flap is working properly as well. they are in your owners manual.
Maytag MSD2454G... | Answered on Jul 04, 2014
When you use a glass and try to get water, if you hear a click or buzzing sound, the water switch is working, if not it is an electrical problem, the water solenoid valve could be bad, or the switch. One other thing to check is the filter on the water line. Some have an extra filter. Turn the water off, disconnect the filter and see if you can blow through the filter. There is a screen filter just before the water valve check it to.
Maytag MSD2454G... | Answered on Jun 22, 2014
You have a defrost, or air circulation problem. If there is ice on the inside of the freezer walls it is probably a defrost problem, provided the freezer fan motor is running. If it isn't running the fan motor is the problem. If the motor is running it is a defrost problem. Three things can cause a defrost problem, the defrost heater is bad, the defrost terminator is bad, or the defrost timer is bad. On the newer refrigerators the defrost is controlled by a control circuit board. If it is bad it can be expensive. If you have an older refrigerator, I recommend replacing the defrost timer, the defrost heater and defrost terminator. When one goes bad, it effects the stability for the other parts to function properly, so replacment of all is best.
Maytag MSD2454G... | Answered on Jun 09, 2014
when you put it back in for the last time does it do anything? Does it make any noise or movement. If it does then check to see if water is coming into the ice maker. if it is not then you may have a water inlet problem
Maytag MSD2454G... | Answered on Jun 04, 2014
Most likely the condenser coil is dirty. It is under the fridge, clean it with a vacuum, or air pressure, blow it out outside it will ne dusty . There are two to three fans. One by the compressor, called a condenser fan. If it is a side by side, usually there is a fan in the freezer section, and one in the refrigerator section. All need to work. If all this is and the compressor is running then chances are the compressor has bad valves. Make sure there is no ice on the coils in the refrigerator and freezer coils. If there is ice you have a defrost problem, which can be fixed. If the compressor has bad valves, get a new refrigerator.
Maytag MSD2454G... | Answered on May 08, 2014
Maytag MSD2454G Side by Side Refrigerator Logo
300 questions posted
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Refrigerators
Most Popular Question
ice forming bottom freezer leaking water
  • Refrigerators
