20 Most Recent Maytag MZD2766GES Side by Side Refrigerator Questions & Answers
Who is the brand?
Maytag... | Answered on Jan 07, 2018
A defrost water drain pan should located under the unit on top the coils. Or in the outside in back mounted on top of compresser
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Maytag... | Answered on Jan 02, 2018
damper control motor failure call service tech
Maytag... | Answered on Dec 29, 2017
Check your fan next to the compressor if it's running ,also check your evaporator fan if it's running.
If both fans are running and you still have ice built-up then you may have a refrigerant leak
Maytag... | Answered on Dec 21, 2017
Yes... Hello sjscycle (Steve),
Good thinking
A No water CONDITION in the ice tray would tend to
POINT FAULT at the (ice-cube) water valve... but
The voltage for the valve comes from the
ice head..
If you can negotiate (fit a water bottle up into the
ice tray)... if the tray cycles & does not refill...
it is VERY LIKELY... If the part were more exotic
or expensive it might be WORTH the RISK of live
voltage testing
... Personally I WON'T RECOMMEND
live testing...
The fitting appears to be the new (easy to use)
press type... Press white collar to RELEASE...
Press tube directly into valve...
SIMILAR to the new SHARK Bite solderless fittings now available in most hardware stores (nice & easy).
Watch the attached video... and decide for yourself.
Electric shock (if not fatal) is quite painful to most.
Let's watch the (2) videos (you will be happier).
Video, part & price
http://www.appliancepartspros.com/whirlpool-water-inlet-valve-61005626-ap4071513.html
Appliancepartspros DIAGRAMS
http://www.appliancepartspros.com/parts-for-maytag-mzd2766ges.html
Partselect.com (another video)
Whirlpool 61005626 Double Outlet Water Valve PartSelect
Part select's trouble probabilities
http://www.partselect.com/AdvancedModelSymptoms.aspx?ModelNum=MZD2766GES&mfgModelNum=&fkMfgID=1&Source=msac&term=MZD2766GES&utm_source=adcenter&utm_medium=cpc&utm_campaign=bing&match=p&utm_content=m13775907013&sw=partselect+water+valve+mzd2766ges&ModelMasterID=224891&PID=12
You will notice... at no time did the word "Sears"
get recommended (same parts... ((get them elsewhere)..
Unless SEARS suddenly starts giving them away).
Hope MY OPINION helps.
Carnac the Magnificent
Maytag... | Answered on Jul 22, 2017
2 possible issues. If compressor running, but not cooling - No freon in the system, or compressor valves are bad, not compressing freon. Ideal would be to check pressures on the system while its running. Could be some kind of restriction. most common problem i would guess low freon level. Here are 2 of my videos i have on my channel. first is leak found at evaporator coils. i used leak dye to find it, second video is replacing compressor, but had compressor completely down. installed 3-n-1 hard start kit, but compressor did not come on, so replaced compressor with filter drier. Hope this will give you an idea what to do next.
Maytag... | Answered on Nov 21, 2015
The problem with those auto light panel`s is the device (photo-cell) responsible for sensing when to activate the light is common to fail. But before replacing it, follow the direction`s below to secure the ribbon connector to insure it is making a good connection.
Unfortunately the failed component is integrated into the outer trim and which can only be resolved by replacing the outer panel assembly called an ``escutcheon`` part # 61005386 and retail`s for around $120-$150, so I`d shop around.
It is easy to replace if need be, but as you can see not cheap. If you do change it, make sure you shut off the breaker before pulling the escutcheon/front panel off. If you look at the panel from the bottom, you should see a couple of slot`s just large enough to slide a small flat screwdriver behind to allow you to pry it off. From there you can lift it up and off, (careful not to scratch the freezer door) but you`ll need to unplug the ``ribbon connector`` from the panel/escutcheon. Reverse this when installing the new part and you should be fine.
Hope that helps. Good luck and thank`s for visiting fixya.
macmarkus :)
Maytag... | Answered on Jul 24, 2015
To aid in troubleshooting, the link below may be of help:
MAYTAG MAYTAG REFRIGERATION Parts Model MZD2766GES Sears PartsDirect
You may have a failed defrost heater.
Maytag... | Answered on Jun 27, 2015
Maytag push and hold reset for 3 to 10 seconds
push and hold light and lock pad same time till blinks at ya set for another 12 months
Maytag... | Answered on Feb 21, 2015
It is in the top refrigerator shelf behind that plastic shild. Take the shild off and I think that model is just a quarter turn and the little cylinder comes out
Maytag... | Answered on Jan 28, 2015
Even if the unit if issue free, this older design is still suseptable to moisture intrusion behind the inner liner. If your ice is below or around where the fointain area is, than you may be leaking water from the fountain behind the outer door shell. Since your outer door and inner liner are no longer avail, the best suggestion is to turn the entire fridge off, and let everything completely dry before re assembly. Once insulation gets imbedded with moisture and freezes, the insulation factor diminishes. Although your outer door insulation should be the newer style semi solid foamed in style, so moisture intrusion will not be any deeper than an inch or so. If the fountain heater has failed around the dispenser, you attract moisture to that area too. Pleazer Appliance...
Maytag... | Answered on Jan 07, 2015
It should be marked. And you should have a water line kit with it.
Maytag... | Answered on Nov 07, 2014
you dont give any detail at all, so my best guess is you have a sealed system leak of refrigerant. This is NOT something you can repair yourself, only an EPA Certified Refrigerator Repair service can perform these types of repairs. Its possible it might be something else, I am just guessing after all, i would have a qualified refrigerator repair service inspect and diagnose your fridge.
Maytag... | Answered on Nov 06, 2014
Carefully lay the unit on it's side and go from the bottom
Maytag... | Answered on Oct 11, 2014
Maytag MZD2766GES Side by Side Refrigerator Logo
625 questions posted
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Refrigerators
Most Popular Question
water filter located replace
  • Refrigerators
