20 Most Recent Maytag MTF2156GEQ Top Freezer Refrigerator Questions & Answers
more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. Over time it gradually builds and starts voer a larger area. Being you have a top mount refrigerator(freezer on top) there are air ways that connect the freezer to the fridege, which is how its cooled. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt
If thats not an option that you want to use the actual repair method would be to 1) unplug the machine 2) empty everything out of the freezer so you'll have room to work 3) take all the shelving and baskets out 4) locate the screws on the rear wall inside the freezer and remove them 5) take the back panel off exposing the evaporator coils ( the aluminum ) 6) directly below the coils is a trough of sorts and the drain is usually in the middle and runs out the bottom, remove the ice by carefully chipping it out or by using a hair dryer or hot water. 7) once all the ice is gone, the drain is visible and water can flow smnoothly down the drain dry the area and reassemble.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Maytag... | Answered on Jun 02, 2012
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Maytag... | Answered on Sep 11, 2010
the fact that ice was built up on back of freeezer tells me that the refrigerant system is probably ok. most likely from your description you have a defrost system problem. whne ice builds up very heavily it starts to act like insulation (think igloo) so it will allow frozen foods to thaw and fresh foods to spoil. here is how to check. in refrig compartment I need you to remove the control panel/light lens in rear, these are held in place by the control knobs and then you pull out on the cover to release. once this is removed I need you to look for the defrost timer there will be a hole to the right of the temp controls it has a grey or black looking knob in it that you can turn with a flat tip scre driver. turn this knob until the unit clicks off. now you will have to wait a few minutes but listen in the freezer compartment for a sound that sounds like water falling into a hot frying pan, you may also notice a glowing red light at teh bottom of the cover in the back of the freezer.
if the heaters don't come on then the timer is ok. teh next step is remove the rear freezer cover and defrost the ice out of the coils. you can use a hair dryer, or a wet dry vac set to the blow position. once the ice is gone inspect the heaters for burnt or broken condition. (ge uses glass rod heaters and heater breakage is very common) I suspect the heaters are the problem anyway.
be aware that you are going to get lots of water the drain pan will not contain all of the defrost form this bad a freeze up. good luck peyton
Maytag... | Answered on Jan 29, 2009
Do you have ice build up on the back wall in the freezer? If so you have whats called a defrost problem. (can be timmer, adc, heating element or thermostat)... All cold air in you fridge side come from the freezer, therefore if you have ice build up behind back wall in freezer it is blocking air flow....
Maytag... | Answered on Jan 07, 2009
test the supply with a meter
Maytag... | Answered on Dec 23, 2019
YOU GENTLY SQUEEZE THE PLASTIC TO GET IT OUT OF THE WAY
Maytag... | Answered on Dec 13, 2019
Slide the frig out, (Unplug Frig. first) remove the cover so you can see the condenser, beside the condenser there is a switch that has to be carefully removed w/(fasteners) Take to your nearest appliance store, last time I did this it was like $52.00. Carefully plug-in, take not were the wiring goes usually they only fit just one way. reassemble cover, plug-in you should hear it kick on, good luck.
Maytag... | Answered on Oct 01, 2019
If you go to https://www.filtersfast.com/Maytag-Refrigerator-Water-Filters-cat.asp
It will show you styles of Maytag Refrigerators. If you click on the one that matches your style, it will show you possible areas the filter is located. You can then look in those areas. Once you locate it, then you can then identify your filter part # and replace if needed. You can also go to Maytags website and look up your model and find the manual. The manual will likely tell you where the filter is and what the part number is.
Maytag... | Answered on Sep 17, 2019
Is icemaker switched on. Usually located near icemaker/ Or maybe faulty switch
PLEASE CHECK THE CONNECTION CAREFULLY AND THEREAFTER IF NOT WORK THEN CONTACT TO WELL MACHANIC.
Maytag... | Answered on Sep 15, 2019
There may be a drip tray under the fridge, it needs to be checked and position properly
Maytag... | Answered on Aug 22, 2019
Maytag MTF2156GEQ Top Freezer Refrigerator Logo
Popular Tags
8 questions posted
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Refrigerators
Most Popular Question
both freezer refridgerator quit
  • Refrigerators
