20 Most Recent
Maytag MSD2732GR Side by Side Refrigerator Questions & Answers
Ice buildup at bottom of freezer and small puddle.
Freezer has a drain in the back under the cooling coil. Melt Ice from drain area with a hair dryer, check drain and clear, under bottom in back behind a removable panel you will find the drain exit from the freezer going into the drain pan. This drain line has a loop for air seal, make sure it is cleared.
Msd2454gr grinds when dispensing ice
if it grinds the ice when set on cubes ice output,remove the ice holder from the freezer and check for a chunk of melted ice blocking the hole to let cubed ice come past the chopper blades,run hot water thru this container till all blockage is melted then dry it out throughly put it in freezer and let it get freezing cold before letting new ice fall into it so you dont have a repeat of the same problem
Water dispenser won't shut off
If this is just the water dispenser it sound like the door switch or dispenser switch has failed. Remove and test for proper function, if this is okay then move to the control valve there is usually one for the water and one for the ice although they may be packaged together in a single unit. Unscrew each line and see if water it constantly being sent to the door and icemaker... it should only do that when the switch is activated.
Freezer door opens
This sounds like an alignment problem. Loosen the hinges slightly and place the door in the closed position and duck tape it in place. Tighten the hinges and check it for seal. Door is heavy by itself so empty it first and work with some help.
Why doesn't commercial refrigerator close all the way
This sounds like the cams that control the close location are out of alignment. Loosen up the hinges, align door and duct tape it in place. Tighten hinges, remove tape and you should be good to go. Door is heavy so unload first and have an extra set of hands.
The dispenser light won't turn off and ice and water not working after filter change..
I'm not really sure of this one but here's a couple ideas. If the refrigerator ice and water dispenser is not working the dispenser control board might be defective. The control board governs most of the functions of the dispenser system. If only one item of the dispenser system is not working, troubleshoot further to see if the problem is with one of the components in the system. The board is more likely to be the cause of the problem when the entire dispensing system fails. It may also be the door switch If the refrigerator ice and water dispenser is not working. When the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice maker dispenser. If the door switch fails the dispenser will not turn on. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.Before either of these try shutting it off (or place it in demo mode) and return is to active state.It may just need a reset
Refrigerator running warm
Would you post the correct model number so I can look up what parts that may be causing this? Is MSD2732GR the correct model number? Is there any cooling at all? Is the problem only in the fresh food section? I am here should you need me, Thanks John Tripp
Appliance 911
Contact Me Here
My Maytag side by side (no icemaker) keeps leaking
OK, You need to unplug for a hour or so. Remove the rear panel in back of freezer to expose the evaporator coils. At the bottom of the evaporator there is a tray that catches the defrost water to take it through the back and down to the condensate tray located near compressor and condenser fan. Most likely you have ice or something trapped in that drain beginning in the freezer. I have heard some people turn the freezer temperatures so cold ice will form before the water can drain. If you still have problem contact me. If this helped vote or rate me. Thanks Sea Breeze
