20 Most Recent
Nokia Handsfree For 6020, 6101, 6102 Headset Questions & Answers
My phone is broken so
What phone is it?
If it is an iphone it will be easy to repair. Just have the whole front screen swapped out including earpiece.
You can get these of ebay for 20-30 all in.
Restriction code for nokia x2-01
My dear please check this way
Code #pw+123456789012345+1# type in the following way:
1. Turn on the phone without sim card
2. Type #pw+123456789012345+1#
3. Restart phone and
5. Message "SIM restriction OFF" appears, Your phone is now unlocked
WARNING!!!
You have only 3 attempts to enter the code. The last failed attempt will block the counter.
Restriction code for Nokia 6020
Note : Please try unlocking your Nokia 6020 mobile phone only once using the steps given below with the Nokia 6020 unlock code you get from our unlocking tool. If it does not work, do not try again as it may get your Nokia 6020 permanently locked. Do not enter any wrong unlock codes on your Nokia 6020 mobile phone. If you enter over a certain amount of wrong unlock codes on your mobile phone, your Nokia 6020 phone may get permanently locked and sometimes become unusable.
1 - Switch on your Nokia 6020 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6020.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6020 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6020 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6020
Nokia 6020 restriction code
i have nokia 6020...i would like how to op0en the restriction codes from my phone..
the serial no is:355549016743699......
I have a nokia 2700
do you have data cable for nokia 2700??if yes use nokia pc suite, you can download it from nokia homepage
i hope this helpfull
thanks for using fixya
To remove call barring activation
Call Barring - Enables you to restrict or bar certain or all types of
calls to and from your mobile phone, i.e. outgoing calls, outgoing
international calls, incoming calls. Barring is activated with a
personal code.
Call barring is a mobile phone feature that allows the user to set
certain prohibitions on incoming or outgoing calls. This is an effective
means to prevent the phone being used to make expensive international
or premium rate calls, particularly when the phone is to be used by
people other than the subscriber.
Many companies that provide handsets for business use now employ call
barring as a security measure, to control their use and restrict calls
to pre-approved numbers. The user's personal code must be used to
activate this feature.
How do I get it?
Contact your local Service Provider. You will need a four digit barring
code. Initially this will be 0000. You should create a personal barring
code for security. Please consult your cellphone's instruction manual.
What does it cost?
This service is free.
Also you can deactivate it from your cell phone..
Different cell phones have different setting functions,
You can try these out. It's the general way to deactivate call barring (NOKIA) .
Follow the below instruction:
Go to Menu,
Enter settings,
Scroll to Security,
You will see call barring on that list,
Click on it,and scroll to last option and you will see cancel call barring.
Your cell phone might not be the same with these functions,but the procedure are aways the same..
Good luck.
